Question about Copystar Office Equipment & Supplies
ERROR C 0420 - Copystar Office Equipment & Supplies
Error code: 0420:0010060?
This is refer to communication error between the printer and the extra drawer. If you power on the printer without an extra pf unit, does the printer power on?
Aug 13, 2014 | Kyocera FS1370DN Laser Printer
Code P 0420
There are numerous things that can cause this code to come up.First how many miles do u have? U have to make sure there are no exhaust leaks by the down stream O2 sensor. Also have to make sure there are no fuel delivery problems or vacum leaks. If u have access to a scanner for your vehicle u will have to look at your fuel trims and make sure they are around 0% at idle and off idle. Also have to make sure your O2 sensors are working correctly. Post some more info for your vehicle and i can guide u in the right direction
Jan 10, 2013 | 2006 Chrysler Pacifica
Hi, my neon 2004, have the code: 0128,0551, 0420, 0622, 0517, 0563. I wanted to mention that it does not have catalyst, what could these codes mean?
A real smorgasbord!
0420 is for the cat, so scrub that one. I could not find 0517-don't know what that means. 0551 and 0128 are sensor malfunctions, or circuit malfunctions for those two sensors (P/S pressure switch, and Coolant temp. sensor). Before going after that, take heed of 0622 and 0563: 0563 is system voltage too high, 0622 is generator field "F" control circuit malfunction. You have a bad voltage regulator in your alternator-putting out too much current. Try a different alternator-it may clear up the sensor malfunctrions, too.
Nov 30, 2012 | Cars & Trucks
Minolta dialta error c 0420
Exposure lamp is out or the board that controls it the exposure lamp is the very bright light that comes on, on top of the machine as it scans the original document. once replaced open and close the front door.
Sep 07, 2012 | Minolta DiALTA Di181 Printer
What should i do if i get a 0420 code on a 2003 ford taurus
Trouble code P0420 means: Catalyst System Efficiency Below Threshold
This is unrelated to the noise when turning sharply or the grinding when braking/brake light.
Feb 27, 2012 | 1993 Ford Taurus
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
1998 Chevrolet Cavalier 0420 Code
Here is something from a reference guide that we follow at my shop, hope it helps.
When diagnosing a PCM code PO420, be sure to determine the cause of the converter failure. Converters are not likely to fail without an external cause. Typical causes are: fuel pressure regulator leak, engine misfire, dirty fuel injectors, coolant consumption, etc. Also, be aware that some converters on the market will cause this code or codes due to a lack of oxygen storage capacity. A component that must be in these converters, Cerium, is required to store, then slowly release oxygen.
Mar 10, 2009 | 1998 Chevrolet Cavalier
Check Engine Light
Hello engelhard58
I have attached a link that can give you some of the reasons why your getting that code.I hope you able to get your answer out of that.
Mean of the code=P0420 Catalyst System Efficiency Below Threshold.
Link to site
Dec 12, 2008 | 2005 Subaru Forester
43 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
