The Woofer on one of my speakers has no sound coming from it. I have them bi-wired so I switched cables and still the woofer produced no sound, leading me to believe that it is a speaker fault rather than cables or amp. The speakers sit on spikes on Mission Stance stands, as far as I know they have not been knocked over, at least, no one is admitting to it!
Can I safely remove the back panel and check the wiring or is this best left to an engineer?
If these are Mission 780s your talking about, you're not the only one. The woofers supplied with the speakers originally have a known design/manufacturing flaw causing them to go "open circuit" after a few years use.
The good news is that IAG (who now own Mission) can supply you with a pair of replacements for about £45 plus postage. (You'd be forgiven for thinking they should supply the replacements for free given the cost of these speakers new and the fact this is a design/manufacturing fault).
Replacing your woofers is easy. Take off the front baffle. Remove the four rubber plugs that the baffle attaches too, and take out the 4 screws you'll find behind them. Now ease off the plastic moulded front pannel. Remove the four screws holding the woofer in place. Pull the spade connectors from their tags on the back of the speaker. Put the new woofer in by following this proceedure in reverse.
First, check if the speaker coils are blown (open Circuit). Take a multi meter, and, after removing the cales connected to the speaker, check for continuity. Reading should be either 4 or 8 Ohms. If there is no continuity, then there is nothing you can do except get a replacement. There is no need to get a technician to to do this basic check.
The guy from missionparts@hotmail.com has these woofers available in North America. He is very knowledgeble with Mission products and provided quick delivery.
Was this helpful?
Yes
No
Solution #5
posted on Apr 04, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
IAG have just lowered the price to £58 inc delivery.
My problems are the sound in my boxes are some times good and otherwise i here sound with a bromming...
(More)
My problems are the sound in my boxes are some times good and otherwise i here sound with a bromming in the speakers
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew...
(More)
My SW 22HT Kenwood subwoofer stopped working.The fuse was bad it was replaced and the new fuse blew again
Acoustic Solution DVD/TV Combi 15" Portable Model Number : P4180 Screen Language is in...
(More)
Acoustic Solution DVD/TV Combi 15" Portable Model Number : P4180 Screen Language is in Russian I think. How do I change it to English ?
