Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
Posted on Feb 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2009 lawnboy walk behind mower with the B/S engine model # 124T05. The problem is, it starts easliy and the stops after about 2 seconds, but if I hold the choke closed 95% it keeps running like a champ, Any ideas?
charles beach
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Briggs & Str... Master 1,917 Answers
  • Posted on Jun 07, 2014
charles beach
Level 3:
Renaissance:
Answers
1917
Questions
Helped
569696
Points
3010
Needs carburator kit to fix rebuild carb
1 Related Answer
Anonymous
  • Posted on Jun 02, 2011
SOURCE: Lawnboy model 10640 walk-behind mower
I have the exact same problem. I read on another site that the blowout hole in the back of the mower where the grass goes into the catcher must be cleared of any grass or dirt. I don't use the grass catcher and indeed the hole was full of dirt and grass. I cleared out what I could with my hands and a screwdriver, and magically somehow the cord retracted about a foot. Enough to start the mower with. It still doesn't retract all the way, but it was an improvement. I may have worn out the spring pulling and tugging on it trying to get it to retract, but ok for now.
Please share if you find a more permanent solution. Mower is barely a year old.
Lawnboy model 10415 serial number 5901752 correct spark plug
Joe, Factory Lawn Boy SPARK PLUG 614009, replacement plugs champion CJ14, NGK plug # BMR4A.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Boy 10415 Lawn Boy Gold Series Walk Behind Mower 1995 SN 5900001...
614009 Spark Plug
Which spark plug for Lawnboy engine
https://www.shoplawnboy.com/Comergent/en/US/adirect/Toro?cmd=ToroLBOnlineModelLookup
Aug 04, 2016 • Garden
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
Briggs and Stratton
clogged fuel line. the choke restricts air flow if it runs fine choked it is probably getting too much air to run properly. those 2 seconds it is most likely running off a surplus of fuel from priming or something of that sort.
Check fuel lines and fuel filter for obstructions. I reccomend replacing fuel filter also. If this does not help is may be a fuel issue in the carburetor.
Feb 08, 2012 • Garden
Lawnboy mower will not idle up under load
the lawnmower is not designed to idle with a load on the engine, it needs to be operated at full throttle
1helpful
2answers
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 • Garden
2helpful
What is the 2 cycle oil to gas mixture for a 2 cycle lawnboy
20:1 gas to oil is a good place to start. Some mowers thin down to 80:1. If you can tell me the model of the mower I can be more specific, but starting at 20:1 will assure you have adequate protection for the engine. If it's exhausting lots of oil smoke after it has warmed up; you can cut back a little each time until you have minor oil smoke.
at 20:1 you need to add 6.4 ounces of oil to one gallon of gas.
Here's a nifty calculator for various ratios:
http://www.csgnetwork.com/oilfuelcalc.html
Enter 1 gallon of gas, then change the ratio number and then press calculate and the number of ounces per gallon will be displayed.
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
