Question about Electrolux Vacuums
Can't get the covers off Electrolux Model C102G, acts as if bag is full, but bag is new and empty!
Acts as if bag is full but bag is new and empty!!
  • Walt Clifton Feb 10, 2012
    new situation with the Electolux 6500, I have the covers off and have discovered that the bag door switch apparently is operating correctly? But it still cuts off when I put in a new clean empty bag. I even put a bag over the input to the suction and it will run, I wonder if the swith mechanism to adjust for the fullnes of the bag is broken? But at least I have the vacuum opened now so that I can look at things. any help would be appreciated????
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
  • 44 Answers
SOURCE: I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Posted on Jan 03, 2009
  • 44 Answers
SOURCE: electrolux 2100 new bag placed full bag indicator appears
It appears you have a bad control valve. My suggestion is to take it to your nearest Aerus dealer and have them replace it for you. You can find them by going to aerusonline.com and use their dealer locater. It shouldn't cost much to replace. You can disable it, but I don't suggest it. It is in place to protect you motor, and assuming you bought this machine new, you are aware of how much they cost. If you can't find a dealer locally, call the closest one and they may ship you the part. If you have to do it yourself, here is how. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come off relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. Pull the bag housing out, and the control valve will be right there. It's circular with vacuum lines connected to it. Just pull it out and move the vacuum lines to the new one, but be sure you get them in the right position!. It won't work if you don't. I hope this helps. Good Luck!!
Posted on Jan 04, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
  • 430 Answers
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Posted on Dec 17, 2009
My electrolux vacuum cleaner?
Sometimes the bag isn't installed properly.
Try removing the bag and replace with a new one making sure that the bag is in the bag compartment squarely on all four corners thus covering the bag door switch. Close lid and try again.
Hope that helps!
Mar 14, 2015 | Electrolux Vacuums
I just purchased an Electrolux Epic 6500 SR, Model #C102G. I found that inside the cover over the bag. But where is the Serial number? I can't seem to locate that anywhere. Also, in case it breaks, I will...
The serial number is on the bottom of the machine. I believe near the front wheels, but can't remember for sure.
Parts can be purchased at any authorized Aerus Electrolux store. You can locate the one nearest you using the below link.
http://www.aerushome.com/storelocator/
And you can find a manual for it using this next one.
http://www.aerusvacuums.com/support/manuals/
Mar 03, 2011 | Electrolux Vacuums
We have an Electrolux 6500 SR Model C102G. We
yes it wears out it is a common problem i eliminated several of them for people its a job that takes alot of patience i opt to just eliminate the part its sort of useless and causes your machine to act contrary if you want to replace the part here is the place Electrolux Aerus 4526 Maccorkle Avenue
South Charleston, WV 25309-1409
(304) 768-2158.. if you cant fix it contact me and i will repair it for $35.00 plus parts or no parts either way it can be fixed the above contact is the dealer i use for parts
Jun 13, 2010 | Electrolux Epic 6500 Vacuum
13 yr Electrlux.Cuts off if hose plugs in.Says Bag Full-bag empty
This sounds like the valve assembly (full bag control) is faulty or one ov the tubes is clogged. You will have to take it to the shop.
Jul 15, 2009 | Electrolux Guardian Bagged Canister Vacuum
sounds like you have the plastic bodied canister. the controll valve inside is bad. I usually just disconnect those to avoid future problems. you may want to take the vacuum to a repair shop though becuase they are a pain to get apart and get back in one piece.
Jul 15, 2009 | Electrolux Vacuums
Jan 01, 2009 | Electrolux Epic 6500 Vacuum
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
35 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
