Question about Whirlpool Washing Machines
Whirlpool cabrio washer won't go into diagnostic mode.
Having spin drain issues , lid lock light sometimes blinks but locks, followed procedure to diagnose but wont go into diagnostic mode
  • jimbo Feb 12, 2012
    does not display any codes.
  • 1028 Answers
SOURCE: The Lid Lock will not
bad lid lock most likly cause..clips under edge of top release top switch mounts to front edge of top and wires runs to control under console
Posted on Apr 27, 2008
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool Cabrio not draining with an F-- error code
This is a name brand oasis and you need to look at the larger pump on the right side once you have pulled the machine out 2 feet and tilted it back to expose the bottom. You should get a large tray like for changing oil and remove the hose. The black hose closer to you is soft rubber and will take some patience to work with. I would pull the hoses and drain what is left of water at the bottom of the tub. Warning if the tub is full of water you are going to flood your house so try and pump it out first. When the hoses are off inspect the water for debris or scale build up, check the pump for anything that can block or stop rotation of the impeller.
Posted on Sep 20, 2008
SOURCE: F02 error on Kenmore front load, followed solution, problem still exist, What next?
the button trap is the "filter asssy" are you moving water tought the drain cycle at all, ive seeen that the pump assy has been damaged in such a way that the impeller has disloged form pump and no loneger pumps water effectivly, usually soundslike its working though perhaps a little louder.i would also check perhaps theres a blockage in the hose that connects the tub to the pump assy. there shoudl be a soft ball sized plastic ball within the hose( just pointing that out so you dont remove it)
Posted on Oct 29, 2008
  • 530 Answers
SOURCE: Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
Posted on May 12, 2010
  • 403 Answers
SOURCE: the load finished on my
you need to replace the lid lock. the latch probably broke in 2, and the broken part is whats keeping the lid closed. if you have clothes inside you can open the top by using a putty knife to release the front clips holding the top of the machine down. push each clip in and lift up. you will also be able to access the lid lock this way.
Posted on May 05, 2011
My Magtag Centennial washer won't spin
This washer shouldn't do anything unless the lid is locked. When you start a cycle, does it lock? After drain, does it unlock the lid right away? There is a manual inside the cabinet that will tell you how to get into diagnostic mode to check for error codes and run the machine through it's functions
Jul 18, 2016 | Washing Machines
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
GE WASHING MACHINE NOT AGITATING OR SPIINNING. IT FILLS AND DRAINS. WHHAT COULD BE THE PROBLEM. ITS A TOP LOADER. MODEL WDSR2080D0WW
if you open the lid, you should see a white plastic rectangular piece on the front right corner. try taking a magnet ( stronger the better) and placing on top of the plastic piece. that plastic piece is part of your lid lock assy. sometimes the magnets inside that plastic piece will get stuck, and won't allow unit to start. If you wiggle the magnet around, if you listen real close, you will hear a light chirping sound. if you hear chirping, lid lock should be ok. If that checks ok, take a look at the motor at the bottom front of the tub. best way to access the motor is to use a putty knife to separate the front panel from the underneath of the top of the front lip. there is a LED light on top of the motor. It will blink a series of blinks if there is an issue that registered any error codes. There is a tech sheet located behind the control panel that tells what blinks mean. Hope this helps
Feb 26, 2015 | GE Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
The lid lock light won't stop blinking.
LID LOCK FAULT
Fault is displayed if Lid Lock has not moved into locked position or motor cannot be powered.
Lid is not closed completely due to interference.
Check for lock interference with lock striker.
Wash media buildup (detergent, lint, etc.) is preventing the lock mechanism from sliding.
Main control detects open lid switch when attempting to lock.
Main control cannot determine if lid lock is in a locked state.
Perform the following checks if the washer does not lock (or unlock).
1. Perform the Lid Lock test under Manual Test Mode on page 9. The following steps assume that this step was unsuccessful.
2. Check lid lock mechanism for obstruction or binding. Repair as necessary.
Oct 20, 2012 | Whirlpool LSB6200KQ Top Load Washer
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LTF2940ES3--Washer drains, but will not do a final spin.
Hi. You have done a great job diagnosing your unit. This unit is designed to not allow a full scaled spin out, if there are issues with the on-board door lock mechanism. This is standard safety equipment for most units. Once this damaged door lock mechanism is replaced, the washer will operate properly. The full scaled spin out will return.
Nov 29, 2009 | Frigidaire Washing Machines
Washer will not spin or completely drain
you could have problem with door lock. or lid switch. this part senses if the door is close.
if it is not functioning, it would interpret it as an open door and will not spin.will not drain either.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
Washing Machines Logo
330 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
