Question about Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor
Sceptre X20G Naga II 20.1" Widescreen monitor
The display driver board in the monitor is failing, according to Sceptre! The monitor stays on for a couple of minutes and then the screen goes completely black. No light around the edges at all. The Blue Light remains on, and I have to turn the monitor off and on several times before it will finally stay on all day!
The part costs $100, but Sceptre will repair it for a flat fee of $75 if I bring it in!
I'm thinking bad component like a capacitor or something equally as simple! I work on more complex electronics than that so I have the technical ability to repair it, but have no idea where to start looking.
Anyone have this kind of problem?
Thanking you in Advance,
theonejrs
  • mike709 Oct 30, 2008
    I have the same problem, I replaced the CAPS but it didn't solve it.
    If I knew what was causing it I could fix it.
I am working on one of these for a customer. Found leaky cap on 5 volt power supply. replaced it, still no backlight. Looked at the inverter with an o-scope and it runs for a few seconds then shuts off. I hooked a ccfl across each of the transformer secondaries on the inverter and it lit up! I believe the problem is failed ccfl units. There is plenty of voltage there to light them up, I have an rf burn on my thumb to show for it. I have not looked at the ease of dis-assembly of the display to replace the backlights. It does not look easy.
Posted on May 29, 2009
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
My sceptre X20G-Naga II , it doesn't turn on, the fusible is good, one of the 2 small led's in the usb board is flashing but low intensity . Do you know about this problem?
Do the caps look OK at least with no leaking/bulging tops. Do you have +5vdc for the logic bd and 12~18vdc for the backlight inverter circuits, those are the first to check. You need to have +5vdc for the set to turn on.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 30, 2010 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
Jan 08, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20G-Naga II 20.1" Flat Panel LCD Monitor Logo
596 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
