Question about Whirlpool Washing Machines
Whirlpool Mod WTW5700SWO wont start
My washer wont start possible the lid switch is gone
  • 1028 Answers
SOURCE: Lint build-up on clothing after coming out of washing Machine
ck to be sure drain hose is not more than 6-8 inches into standpipe ..standpipe is 30-36 inches to top from floor ..drain hose does not fit too tight in standpipe any of the above conditions may cause water to siphon out during wash or rinse resulting in not enough water in tub to carry lint away during drain
Posted on Sep 05, 2008
ghappliances
  • 126 Answers
SOURCE: replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
  • 1122 Answers
SOURCE: how to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Posted on Apr 20, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
Posted on May 16, 2009
jmgldsmth
  • 2005 Answers
SOURCE: replace lid switch
remove the screws on the control panel
pull the panel forward to unseat it then under it pop the clips that hold the top to the back of the washer the rest is self explanitive
Posted on May 29, 2009
Washer fills with water and does nothing will not start mod 110.16862501
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11016862501/0582/0153200?pathTaken=&prst=0&shdMod=11016862501
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 26, 2011 | Kenmore Washing Machines
I need the installations instructions for a Kenmore washer Mod 11020882990 for the lid switch Stella
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020882990/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
Mod. 110.29852992 80 series will not pump out
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.29852992&pathTaken=partSearch
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips,pull the console forward and tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
May 12, 2010 | Kenmore Washing Machines
Kenmore mod 23832100 Lid Switch broken HOw do I
Good day,
There are 3 different style lid switches used on Whirlpool/Kenmore washers. You have to break down the unit to determine which one you use. Any appliance parts house will carry what you need.
Here is an excellent tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 01, 2010 | Kenmore 23822 Top Load Washer
Whirlpool stack washer will fill but will not progress to rest of cycle
It sounds like the lid switch is not making contact. It is a magnet located on the lid so that when you close the lid, the magnet pulls the switch closed. Make sure the magnet is still on the lid. If you washer lid will not stay open on most models, the magnet is gone because this is the same magnet that pulls the lid switch closed. If you can find where it goes, find a strong magnet and place it on the top inside rim where the lid goes when closed. Turn the machine on, let fill with water. Once this is complete and the machine should start. Take the magnet and move it around the rim until the unit starts running. If you can't get it to run, most likely the switch it's self is bad. I think you will find the magnet on the lid is gone and the machine will start running once you pass a magnet over the place where it goes. If so you will need to replace the part.
Oct 17, 2009 | Whirlpool LTE5243D Top Load Stacked...
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Wont start
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Troubleshooting Whirlpool Push to Start Mechanism for Washer
What kind of whirlpool do you have? is it a top loader or a frontloader. If it is a top loader is there water entering the washer? does it not agetate? Does it not Spin. If it does not wash or spin it is a possible bad lid switch close the lid. Do you hear a click? If you have no CLICK sound you have a bad lid switch.
Jan 22, 2009 | Whirlpool Push to Start Mechanism for...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Tub will fill the machine will agitate but when time to drain nothing happens
you need sto check your lid switch , open and close your lid a few times and listen carefully, do you hear a clicking noise?? if not the machine doesnt think the lid is down and wont spin for safety reasons, repalce lid switch p#3949247(if that vcorrect mod num lsq9564j
Feb 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
37 people viewed this question
Dan Webster
Dan Webster
Sal De
