Question about Olympus SP800UZ Digital Camera
I was using my tripod for my camera when my camera suddely fell... Now everytime I tried to turn it on, it will says 'zoom error'... Can somebody help me? My dad gave it to me as a present...
Is there any way that i can fix it without taking it to service?
SOURCE: Camera Stopped Working
Ok so this is a bit late to help probably but the same thing happened to my camera (exectly the same make and model) two weeks ago. I had been on the beach and suspect that some fine sand had got into the mechanism but do not know for certain. I have got it working again by unscrewing the camera (watch out for the screw hidden under the rubber cover for the connectors - and 2 at the memory card cover - the others are quite obvious. Also be aware that there is an interface and 2 wires that connect the back (with the screen) to the motherboard so don't pull them apart too hard. I kept the batteries in (you have to hold them in place in the compartment, and got a mini hoover I use to clean my PC keyboard, and placed it so that it could clean under the motherboard - there are spaces around the edge where you can do this. Suddenly the lens came to life and extended corrently. Big smiles from me! I then re-attached the casing and screwed it all up again. Working as good as new now. You may has well have a go - repairs are almost the cost of new one apparently and it was out of warranty so I didn't feel I had anything to lose by having a go.
Posted on Aug 05, 2006
SOURCE: Zoom Error
Have you tried changing the batteries to new/charged ones?
Posted on Oct 17, 2008
SOURCE: Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Posted on Mar 15, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
lock123
  • 6831 Answers
SOURCE: Zoom Error in my camera olympus M 730
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Hi My Nikon D5100 camera giving a sin of Autoexposure error. Contact a Nikon authorized representative message after it's drooped from my tripod on the deck floor (Wooden Floor). The Nikon55-300mm
There is no way to really answer this question as the camera was dropped. If it was dropped with the lens, then the problem could be either in the body or the lens (or both). If you have another lens try it and see if you get the same result. Otherwise you are probably going to have to take it to the shop or send it to Nikon
Jun 09, 2013 | Nikon D5100 Digital Camera
I dropped my FUJIFILM S1600 camera and now it doesn't work, is there hope to fix it?
If it was my camera I would put my money towards a new camera.
It is obvious the zoom mechanism/motor is damaged and maybe some other damaged components.
You could get a quote to repair the camera but most likely they would charge you for the quote unless you go ahead for the repair.
Sep 26, 2012 | FUJIFILM FinePix S1600 Digital Camera
My photo shot button fell out that takes photos
Avoid camera shake. Watch your shutter speed. As a general rule, you should not allow this to fall to a speed slower than the reciprocal of your 35mm equivalent focal length. However, if you're using digital (or are willing to use your film up a bit quicker), you can try taking several shots in succession and hopefully one will have a satisfying level of sharpness. Turn on vibration reduction (also called "image stabilization", depending on the manufacturer), if you have it. When VR/IS is on, the lens element(s) or image sensor move so that the image stays in place when projected onto the sensor. As a result, camera motion is less likely to affect the sharpness of your photographs. Turn it on whenever the lighting conditions makes getting a sharp picture difficult. Keep it off when you're shooting on a tripod; it isn't needed and actually makes your photographs less sharp.
Use a shorter lens (or zoom out) and get closer. Remember that, according to the reciprocal rule of photography, reducing your focal length will give you less camera shake at any given shutter speed. Additionally, when you're using a variable-aperture zoom, you can often use a larger aperture with shorter focal lengths. Furthermore, getting closer might force you to be more creative when framing the picture.Use a tripod or a monopod If you're using an SLR and find yourself with so little light that you have no choice but to use long exposures, you might want to invest in a remote release cable. If your camera has a mirror lock-up (also called exposure delay mode), use it; this will stop the vibration from the mirror from affecting your images. Check your camera's manual to see what it's called. Mirror lock-up has two definitions; the other definition refers to when the mirrors and shutters move out of the way after you click the shutter button so that you can clean the image sensor without the sensor being active. If your camera doesn't have mirror lock-up, you can use the self timer.
Jul 28, 2012 | Canon PowerShot A510 Digital Camera
I try to turn of my camera but my zooming in thing doesnt go in and if you want to take pictures it says zoom error also when you try to turn it of the lenses that cover the camera doesnt cover.
Unfortunately, many cameras that fall prey to lens error (zoom errors on Fuji's) problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 03, 2011 | Fuji FinePix F440 Digital Camera
Everytime i switch it on it comes up 'zoom error'
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 07, 2011 | Cameras
How do i get rid of blur warning on a fuji 100
Use a faster shutter speed, lower F stop, / use a tripod, / I don't think that model has image stabilizer, if it does turn it on. If this usually happens when zoomed in, try zooming out a bit.
Apr 25, 2010 | Fuji FinePix J10 Digital Camera
When I have the lens 'zoomed' the photos are very
At the maximum zoom, all cameras magnify any tiny movements you make. That's why some cameras now have image stabilization. If yours doesn't, try using a tripod or some solid surface.
Dec 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Olympus SP800UZ Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
