Question about Relisys Computers & Internet
I need to solder the power supply coil on my HP vs17e, but i dont know where the coil is located
Im having the same "blackout" problem that is so common with these monitors
  • James Morlin Feb 08, 2012
    it was said online that it was an easy fix.. all i have to do is resolder the connecting points on the power supply coil... where is it located on the board???
Here is a link to download the service manual http://surefile.org/file/0Txb5
Posted on Jan 16, 2014
SOURCE: Blackout
Try lowering your brightness setting below 55.Its hard to see at just the right angle.The monitor has a failsafe installed for over voltage use of the bulbs for the screen. The lights go out but your screen is still there.
Posted on Aug 11, 2007
freetek
  • 5568 Answers
SOURCE: hp vs17e monitor manual dowmload
For Jimmy- HP's website is a nightmare but I'm sure the user guide can be had there; it will just take time to locate it.
For Rosignoli- you won't get much help without telling us what kind of computer (Apple - Wintel) the model, operating sytem, etc.
This isn't the psychic hotline.
If you need a general course in computer use, many local schools and libraries offer beginner's courses, mostly at very low cost or free of charge.
Posted on Aug 24, 2008
SOURCE: monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Posted on Sep 13, 2008
pravinbhavsa
  • 348 Answers
SOURCE: need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Posted on Nov 20, 2008
aouate3
  • 123 Answers
SOURCE: my screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Posted on Jun 14, 2009
I have a HP vs17e monitor and for last 2 days it will only stay on for about 3 seconds then go black the blue power light is one and no blinking. any ideas what is going on?
It can be the power supply, backlight inverter circuits, bad lamp assemblies.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 11, 2011 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP-VS17E monitor that will come on but go back off within 2 seconds. If I turn the monitor off and back on it will still just come on for a couple of seconds and then go blank. Is there anything I...
Look for bad caps first, worst case will be bad lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor hpvs17e stays on for second and goes blank
gldngrlz411, most likely problem with internal "switch-mode-power-supply" / CCFL inverter supply that provides 600 to 1000 volts ac to light the CCFL tubes that provide "white light" so you can see what is on the glass LCD panel!! Explore here first: http://www/lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ If vs17e does same when connected to a different "known good" pc, then you will need to make big decision!!! FIX or Trade in for new wide screen unit. 12fixlouie
Oct 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
My hp f1703 monitor just turns off on it's own.
Common failure in this monitor is the poor soldering works on the doughnut (4) shape inductors in the inverter board, http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Feb 18, 2010 | HP Pavilion F1703 17" LCD Monitor
HP vs17e sleep after 15 sec when turn on. How to fix it working? tron on it sleeps turn on it sleep
Usually it is from power supply ... cheack it with other power supply... or adaptor..
Dec 03, 2008 | Computers & Internet
Hp vs17e monitor
Hi...there,
That's mean you got a busted backlight inverter, Dude! Replaced a new one or repaired it. Good lucks!
Oct 06, 2008 | HP Pavilion F1703 17" LCD Monitor
Lcd monitor problem
use the economical approach replace the ac power supply if this doesnt work replace your monitor with a new one.
Because its probably the same amount of cost to fix it as it is to get a new monitor.
Jan 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
44 people viewed this question
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
