Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a Samsung HLM5065W. The picture went out but there was still sound. No Lights on or flashing on the front. I unpluged the set let it sit for awhile then plugged it back in. Everything came on and the set looked great for about 30 to 40 seconds. Then the picture just went out again. I did this 3 time with the same results. Any Ideas?
    Problem Solver:
  • 11 Answers
Try searching for a possible "factory reset" for this brand. It will be a secret set of buttons on the remote to enter the default reset menu. I hope that gets you something to try. BTW you should have the original remote or a universal remote with all buttons communicating with the tv to do this. ie numbers, menu, up, down, left, right...
Posted on Jun 21, 2012
  • 1153 Answers
SOURCE: mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 20, 2007
SOURCE: Power problem
OMG!! I had the exact same problem! I unplugged the TV to paint and it stopped working with a flashing green button. I ran my fingers along the bottom of the screen and it actually worked.. wow THANKS A TON!!!
Posted on Jul 06, 2008
SOURCE: Mitsubishi VS-5041 50 Inch Rear Prorjection TV No image but there is sound!
when I try to turn the set on I hear a click like it is trying to turn on , but no sound no picture
Posted on Aug 17, 2008
Slinteriors
  • 8617 Answers
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Posted on Jul 18, 2009
Slinteriors
  • 8617 Answers
SOURCE: blinking green light on Mitsubishi will not turn off
The capacitors on the DM board need replacement, thats a common problem it will work fine but if power is loss even for a minute the capacitor drain, then they cant recharge since they need replacement so the set will just keep blinking the timer light. Installing the V26 DM repair kit from www.tvrepairworld.com will usually repair that. The kit contains the Replacement caps and the CD with detailed instructions.
Posted on Dec 25, 2009
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
3 lights on the front flashing. no picture no sound
The 3 flashing lights is a 'self test' result that says the backlight bulb has gone. You can try turning it off for a few minutes then try again. However, Samsung have had problems with this set and the 3 blinking lights so if it is still in warantee get it replaced asap.
Oct 07, 2010 | Samsung HL72A650 Television
My screen went blank and the 3 lights on the front of the tv were flashing (lamp/temp). I ordered, received, and replaced lamp as I had done previously with this problem. The tv worked beautifully for...
Hi,do you hear any strange noises? if you heart clicking or like wanting to turn on it could be the ballast that's the board that powers the lamp.Do you hear buzzing,whirling,or high pitch sounds?If you do it could be the color wheel which is a little disc looking that when the light of the lamp goes through it creates the colors on the tv.This are the most common failures on samsungs.
Sep 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv will turn on but no picture...stand by, timer and lamp lights flashing
Bad Lamp Part # BP96-00224c- You can find good Deals on Lamp at E-bay i just got one for 85.00 I have the same TV in my bedroom.
Sep 18, 2009 | Samsung HLM5065W 50" Rear Projection...
No picture no sound. All three lights blinking.
Very common for new electronics to have power supply failures. The resistors are built cheaper and tend to fail quickly
Aug 25, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Screen is black tv wont come on, power on lights flash
Replace Lamp ,Go to E-Bay lamp number is BP96-00224c, I just got one for $85.00.
Aug 20, 2009 | Samsung HLM5065W 50" Rear Projection...
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
Flashing
I am currently having the same problem. It started they way you are discribing, but now the TV will do that after the TV has been on for 20min and then will shut off within 30min. Then all the lights up front flash. I have replaced the bulb and that was not the problem. I also NEED HELP! Occasionally the picture on my TV will be inverted and sort of "dance" back and forth on the screen.
Apr 30, 2007 | Samsung HLM5065W 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
