Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire front load washer lights flashing and won't spin
After running the washer with a normal load of laundry during the final spin when spinning out it seemed louder than normal, I didn't think much of it until I started another load of laundry and when it got to the spin cycle it wouldn't spin. After a minute or two the lights came on all flashing and the washer beeped for quite sometime before I hit cancel. I have unplugged power supply and waited a couple minutes as suggested online. What should I do next?
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: My frigidaire front load washer will start a wash,
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Posted on Aug 15, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
    If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
    Posted on Sep 18, 2012
    • 662 Answers
    SOURCE: fiirst started with a buzzing noise, then next load wouldn't spin proper, then not at all, unplugged washer to reset, tried a small load and it won't run water now,after running 10 to 15 minut
    Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out.
    If helped, pl say so.
    Posted on Apr 02, 2013
    Rattling noise in spin, spin problems becoming more pronounced. control panel lights flash but 0 error codes. unplug 2 reset, probl repeats
    If this noise is happening while it's trying to drain water then you have something floating around in the lump. Coins are very common. If the noise is happening during a spin cycle and more pronounced during the final high spin cycle, you have bearing or spin tub issues. Time to go shopping.
    Nov 07, 2013 | Frigidaire ATF6000ES Front Load Washer
    Washer won't spin on spin cycle but spins during other cyles
    Hello rylee1966 - From what you are describing, it sounds like the washer agitates, but it will not enter a high speed spin. If that is correct, more than likely there is a door switch failure. I will personally recommend contacting a professional to move forward accurately and to assist with the repair(s).
    Feb 23, 2013 | Frigidaire Affinity ATF7000E Front Load...
    How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
    Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
    Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
    Door won't open on whirlpool duet washer frontload
    Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
    Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
    There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
    Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
    Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
    Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
    I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
    When my washer did that, I found that the shocks that hold the tub were bad...
    Check out this tip I wrote about the noise and vibration that front load washers can make..
    Washer Problems Washer noise when spinning
    heatman101
    Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
    My frigidaire washer FTF2140ES0 won't spin on the spin cycle
    Hi there, the same thing is happening with our washer. Did you find a solution to the problem? We found a coin the the black tube, but it still doesn't do the final spin. I can hear the motor trying to do something, but it just won't do the final spin. If anyone has any idea or suggestions it would be greatly appreciated. In the meantime, I have a load of slopping wet laundry to deal with. :(
    Jan 04, 2010 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
    Washer won't spin
    Check to see if the strainer before the pump is partially clogged.
    Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Front load Frigidaire Gallery washer
    You are having a door switch problem change it out and you will have a new washing machine.
    Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
    Frigidaire GLTF2940ES Front Load Washer Logo
    248 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
