Question about Toshiba Satellite A205-S6808 Notebook
Toshiba Satellite A205-S6808 keps freezing - Toshiba Satellite A205-S6808 Notebook
    Sergeant:
  • 233 Answers
1-make sure that your laptop's fan working ,if not the laptop become overheated and freez.
2-make surface chek for you HDD
3-test the RAM it can be faulty (if you have more than one peice it could one of them ) make use of memory test tools found on Hirens boot cd it is very useful
Posted on Feb 08, 2012
  • 106 Answers
SOURCE: Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
Posted on May 23, 2008
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Posted on Aug 19, 2009
HEMPYODA
  • 168 Answers
SOURCE: toshiba satellite a205-s5804 keeps shutting down
when you start having this problem it's normally caused by a critical systems error. worry not.. with a little time on your part we can fix this- this is how-
Go here
using a torrent program ie (utorrent2.gif, shareaza, etc) download SPINRITE.exe. Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops. if freedos won't allow the program to run successfully then you need to use a program such as PowerISO to burn the disk and make it a bootable image,
after burning the program to disk-
  • press any key to boot from cd if asked
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
Make sure you run a program like Ccleaner (you can get at www.fileippo.com) to clean your registry and junk files after completion. ^_^
Posted on Sep 14, 2009
Bios password removal
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
If you need any kind of technical assistance for your PC,you can contact support cell at http://www.vtechsquad.com/pc-support
Jan 18, 2013 | Toshiba Satellite A205-S6808 Notebook
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
How to defrag my 205-s6808
Hi
You could try this
start
all programs
system tools
defrag
many thanks
Jun 21, 2011 | Toshiba Satellite A205-S6808 Notebook
I have a Toshiba,Satellite laptop computer. When I type a web address and click serch it takes for along time to do any thing and then I get: Internet Explorer cannot displaythe web page. If then I click...
for I.E 8
close all internet windows, then click on start and select run , type inetcpl.cpl in run box and press enter it will take you to internet properties page select advance tab and click on reset internet explorer it will reset the I.E 8 and then try accessing the site it will work fine.
is still facing same issue let me know via post
Mar 20, 2011 | Lifetime Toshiba Satellite A205-S6808...
Whenever i use my laptop's powersupply, my laptop unit hangs. instead i could only use my laptop using the battery alone and not with the power supply provided. my laptops model is toshiba satellite...
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Reference: Toshiba Satellite A205 Power Adapter
Jan 17, 2011 | Toshiba ADP-75SB AB AC Adapter - 90 Watt...
My Toshiba Satellite keeps freezing. The laptop is a a205 5800 series laptop
Your operating system is corrupted, this can happen due to many reasons (ex:- bad installation). you need a repair operating system
Dec 16, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Need The drivers for Toshiba satellite A205-s5804
Try here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1909174&rpn=PSAF3U&modelFilter=A205-S5804&selCategory=3&selFamily=1073768663&selModel=1909174|PSAF3U
Feb 06, 2009 | Toshiba Satellite A205-S4617 Notebook
I have a TOSHIBA SATELLITE U205-S5022 that freezes constantly.
It would appear you have a bd heat sink you can search on ebay or other sites with tutorial
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S6808 Notebook Logo
178 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
