How to reset the service message
Had to replace a part, when switched on message reads: Service Required 00010020 All lights flashing
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
gwbm
  • 353 Answers
SOURCE: epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Posted on Apr 14, 2009
jacklee366
  • 541 Answers
SOURCE: Service required message
this may mean that your printer needs to be reset i have all epson reseters if you need them
Posted on May 27, 2009
ChobPT
  • 220 Answers
SOURCE: Epson Stylus Photo R300 has error
You actually need to change the ink absorber.
Heres a video on how its done on the R800.
Please refer to your manual for proper localization of the ink absorber.
Doing this will get you to move on
Posted on Jun 20, 2009
How do i reset messages on my v70 03 volvo
The only one you can reset is the "time for regular service" message.
To reset this, turn ignition off, hold the trip reset button down and turn key to position II. Keep holding the trip reset until you hear a ping noise and the orange triangle flashes. Immediately release the trip reset and turn the ignition off.
When you start the car next, the message will be gone.
Other messages like "SRS Service required" or "Alarm system service required" can only be rest with a OBD code reader.
Mar 16, 2013 | 2003 Volvo V70
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
Tip
Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
on Dec 07, 2009 | Ford Windstar Cars & Trucks
How to reset service light
I think the following will work:
1 . Insert key into ignition barrel.
2 . Press and hold the Reset switch (located on the Trip Computer Switchpack).
3 . NOTE: The reset switch has to be released immediately after the ignition is switched 'ON'. This is critical to enable the rest of the procedure.
Turn the key to Ignition position II and at the point of entering Ignition position II (i.e when a click is heard), instantaneously release the Reset switch.
4 . Wait one second.
5 . Press and hold the Trip switch (located on the end of the left-hand side stalk).
6 . Wait one second.
7 . Press and hold the Reset switch (whilst still holding the Trip switch).
8 . The cluster should display (within three seconds) the warning message 'RESETTING SERVICE MODE'.
9 . Keep both buttons pressed until the warning message changes to 'SERVICE MODE RESET' (after ten seconds).
10 . Once the message is displayed the buttons may be released â€" sequence is now complete.
11 . If a Service Required message was displayed prior to the reset sequence, cycle the ignition to 'Off' and then back to Ignition position II and check that the message is no longer displayed.
Jul 12, 2011 | 2005 Jaguar S-Type
I changed the oil in my Craftsman Lawn Tractor 24HP Model No 917-288320 and the "change oil" message on the LED screen won't go away. Is there a reset button somewhere?
Below is excerpt from the owners manual:
SERVICE REMINDER/HOUR METER
Service reminder shows the total number
of hours the engine has run and flashes to
indicate that the engine or mower needs
servicing. When service is required, the
service reminder will flash for two hours.
To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition
key is in any position but "STOP". For
accurate reading, be sure key remains in the
"STOP" position when engine is not running.
It should reset the 2 hours has expired
Jan 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Error says service required
When you get the message service required it usually relates to a warning that your waste ink pads are nearly full and requires you to take the printer to an Epson service centre for repair
You need to have your waste ink pads replaced You may soon find that you will get two red alternating lights flashing this means your printer is locked and unuseable and after replacing the ink pads you will need to reset the printer using software need any more help email me on drummerboy36uk@yahoo.com
Feb 06, 2010 | Epson Stylus R265 InkJet Photo Printer
My printer says service is required is there epson r265
If you are getting the message printer neeeds a service I suggest you get your ink pads cleaned straight away before your printer locks on you Two alternating flashing lights
You need a service utility for the R265 to reset it. you can find one of these on the net free of charge some people are selling them for a fiver but why buy what you can get free if you have problems or need
more info contact me at drummerboy36uk@yahoo.com or MSN using thedrummerboy53@hotmail.com
Jan 25, 2010 | Epson Stylus R265 InkJet Photo Printer
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Message system reads "engine system maintenance required"
WHAT HAPPENED IS WHEN YOU SHUT DOWN AND RESTARTED YOU (RESET THE ENGINE MANAGEMENT COMPUTER) AND THE SERVICE LIGHT SHOULD GO OUT AFTER 10 MINUTES OF DRIVING
Mar 16, 2009 | 2003 Volvo S40
00010020 error
try this may be it helps you --
00010020 CSIC read / write --
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the spanner light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 00010020 will appear on your control panel LCD which is informing you that there is a problem communicating with an ink cartridge. This can be caused by a faulty ink cartridge chip or bent pins. This problem can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Mar 09, 2009 | Epson Stylus Pro 9600 InkJet Printer
43 people viewed this question
k24674
