Question about Sony Playstation 3 (PS3) Console
Why is my ps3 flickering between menu icons itself?
I am having a problem with my ps3, its flickering between the menu icons itself. can you help?
I have a Pioneer PDP-R05FE 43'' TV. When I connect my PS3 to show Blue Ray films I get a flicker in the picture. It is connected using a good quality HDMI cable. There is no flicker when playing SD films...
go into your dispay menu and adjust the response 50-60hrz or if your tv is capped at 1080i then drop the ps3 to 720p and that will smooth it out alittle too as the interlaced picture is alittle choppy apposed to progressive picures and finally sometimes they just do it no rhyme or reason to it so dont go crazy about this ok :)
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
I have playstation 3 and when i turn the main power on ,then it loads the ps3 logo with sound ,but just after that only some almost blue screen is on backround and some white wavy mooving line or...
It sounds like the system software has become corrupted. If you dont mind losing your save games and all other data you could try a PS3 full restore. Turn the PS3 onto standby (red light on). Press and hold the power button until it turns itself back off. Press and hold the power button again until you hear 2 quick beeps together then let go. The PS3 will boot into the recovery menu. Choose option 5 "Restore PS3 system". Let it do its thing and hopefully that will solve your startup problem.
Hope this helps
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
PS3 Graphics Issue
if the problem persists outside of the ps3, i'd say its time for a new tv. however if it doesnt you can try checking your video plug and make sure its still securely in there
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
NO output either HD or normal tvs (not on/off botton hold prob)
Hi, The fact that you are getting a load icon when you put a disc in makes me think you have corrupted system files. If you have a spare 2.5 SATA drive you could put it into the PS3 and let it auto-format it, see if that gets the menu back for you. If it does then your current drive probably needs to be reformatted on a PC and then re-inserted into your PS3.
You'll lose your save games (unlesss you can back the drive up on the PC).
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
