Question about Behringer PMP2000 800 Watt 10 Channel Powered
Berhinger PMP 2000 seems to heat up and shut down
2 Suggested Answers
  • 5603 Answers
SOURCE: On my Berhinger pmp 5000 powered mixer the mic
When using the trim with mics such as SM58's, etc. the trims often wind up at about 3 o'clock in normal use. You set the trims by pressing the PFL buttons down and setting the level using the led display histogram so that at maximum level of talking/singing the display never goes clear up to clipping.
IF you have feedback, then you have issues of mic location and speaker location. The critical point of feedback is far too critical to set with the trim controls.
Your main speakers should be toward the audience from the mics, not so the mics can "hear" the main speakers.
Monitor speakers are ALWAYS a problem with feedback... performers want more monitor, but depending on the acoustics of a stage, reflection from the back can get into the mics or the mics may not be directional enough... SIngers that choose to hold the mic and wave it around are a soundman's nightmare! They let the mic point toward a monitor and away goes the feedback.
The PMP5000 has a lot of power.
While your at it, PLEASE read my tip on FIXYA about PMP mixers regarding the hazard of using Speakon to 1/4 inch speaker cables... ESSENTIALLY never allow the barrel of channel "A" output 1/4 inch to be grounded as it, instead of the tip of the jack is the HOT lead !!!! This isn't in the user manual... I fix these things and discovered this hazard from the schematics.
Posted on Nov 23, 2010
I have a Behringer Europower pmp 5000. Set it up for a show with one mic, left it idle for 20 mins or so then just when I was about to use it I realised it had powered down. Left overnight all come back on...
It sounds like a n overheating problem. Some component is running too hot and shutting down. This will not be a user servicable problem and it needs to go into the shop.
Discuss it with the shop when you take it in to be sure they will have access to the parts they need. Behringer is notoriously slow to ship parts so if it's an exclusively Behringer part as compared to a general electronic part you may have to consider replacing the unit depending on what time frame you have to work with.
Jul 15, 2017 | Behringer Music
How do I set Connect my Boss ME 30 effects peddle .I have a berhinger xeney mixer .Do I need two amps
Try using the insert in/out for the channel you want or the main insert in/out for all channels
Dec 11, 2014 | Boss Music
How to set up a behringer pmp 2000
http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
May 09, 2014 | Music
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
Oct 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
My peavey escort 2000 system starts up works and runs for about 10 to 15 minutes then shuts down and and green light flashes system restarts then shuts down continuously
If after you shut it down and after a while turn it on again and it works the same way. It sounds like a heat problem. We here at Pro Line Music are a Peavey service center. If you can not get any local help you can send it to us.
servicedepartmentprolinemusic@comcast.net
Jun 17, 2011 | Peavey 00511800 Escort Portable Sound...
I have the old 3way 600 watt pa speakers x 2,which amp would you suggest, for this speakers.Because I m having trouble with my amps,that keep on clipping and burning out.
DO NOT run amps into clipping. Also, while the speakers are rated at 600 Watts, you don't want to use an amp that delivers that much RMS. Use about 300 Watts per side. Unfortunately you did not mention the brand of amps you are using. I will also caution you that the speakers have protection networks that if you are getting supersonic feedback that you can't hear that can burn out the amps. DO NOT boost the highs if the mics can "hear" the speakers or the reverberations from them. Solid connection of speaker cables is important. Intermittent connections can fry amplifiers... I won't go into the technical reason for this other than to say the amp's feedback circutis get confused when the load shifts.
You might also have the speakers checked since they can have an intermittent that is popping the amps. If you happen to be using BERHINGER PMP amps, please read my tip about the grounding hazard where the sleeve of channel A is hot and the tip the cold that I have in the Fixya tips.
Mar 25, 2011 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
Where to connect my Subwoofer to PMP 2000
This is NOT convenient with the 2000 unit...ASSUMING you subwoofer has mid and high frequency cutoff built in, what you should do is to mix the two preamp signals in a small mixer and send those to a POWERED subwoofer OR to an amplifier that is driving the subwoofer.
Jan 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
On my Berhinger pmp 5000 powered mixer the mic trim pots seem very touchy.There is almost nothing on them until they are almost at maximum at which point you get feedback issues.How can I check to see if...
Nov 23, 2010 | Behringer Europower Pmp5000 Powered Mixer...
How do I turn on my europower pmp 2000
The power button (push) is in the back, just next to where you plug power cord.
Aug 06, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer PMP2000 800 Watt 10 Channel Powered Logo
125 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
