Question about DCS RGS-366 Professional Gas Kitchen Range
Replace Burner Ignitor DCS range
One burner spark is weak, 1 faint spark per 10 clicks, and burner will not light. All other burners spark fine. I have fastidiously cleaned from the top with no success. Range about 6yrs old. My question: How do I replace the ignitor? After removing the thin nut and simmer ring can I unthread the venturi with a wrench? It does not yield to gentle pressure. In the parts diagram it looks like there may be a nut (#210468) underneath? Anyone have a service manual for this range? Thanks
5 Suggested Answers
  • 4 Answers
SOURCE: dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Posted on Oct 29, 2008
SOURCE: DCS Range constant sparking at all burners even when lighting one
This happens to mine if there is anything on any of the burners, such as food residue or moisture. Check all the burners to see that nothing is touching the burner area where the gas jets are. Even a little water can make this happen.
Posted on Aug 10, 2009
walesarumi
  • 6993 Answers
SOURCE: Two burners on the range
First, try the steps below;
1. Remove the burner cap from the burner base and clean
according to "General Cleaning" section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
If the above doesn't work please let me know so that I may direct you further.
Good luck.
Posted on Jan 14, 2011
AndrexT
  • 20996 Answers
SOURCE: NEED TO REMOVE RANGE TOP. THE LARGEST BURNER NUT HOLDING THE VENTURI IS STUCK. OTHER THREE BURNERS REMOVED OK. DO I HAVE TO SPLIT THE VENTURI NUT TO REMOVE RANGE TOP? I NEED TO GET INSIDE RANGE UNIT.
Yes keep playing with it and BOOOOM! Call in a professional. This is the law with gas appliances.
And turn off the CAPS lock. We heard you the first time :-)
Posted on Jan 24, 2016
Testimonial: "THE GAS WAS TURNED OFF. DUH! WHAT ELSE DO YOU KNOW."
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
Weak ignitor spark at 1 burner
What is the model number of the unit?
Nov 29, 2012 | Kitchen Ranges
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Ignitor makes faint clicking noise but will not light the burner
sounds like a wire is'nt making good contact, check the leads that run up to the ignitors... the ignition module may need to be replaced
Aug 18, 2009 | Garland H286 Gas Kitchen Range
Ignitors constantly click.
Hi, it is possible, that your spark module, need replacing, but it could be other things too. could be faulty ignitor switch, whenever you turn knob to light burner, it activate switch, remove burners, lift top off, you will see, that each knob are connected to valve with two, or some model has one wire, connected to it, check for any breaks in wiring harness, could be something simple like bruise wire touching cooker body, etc. also turn knob and light any burner, turn knob clockwise all the way, let burner light, then gently turn knob counter clockwise and listen to hear if clicking stop, if clicking continue until burner goes off, it's possible you'll need to replace spark module, sometimes, they get short circuited, takes about 30 mins to replace module, $90/ hr. oouch, big companies, does that price, includes, price of module? can you get a regular repair guy, ask a friend they might know one. good luck.
Aug 08, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
DCS RGS-366 Professional Gas Kitchen Range Logo
134 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
