Question about Hotpoint Aquarius WMA52 Front Load Washer
Belt tenstion The belt on the aquarius washing machine keeps comming off on the last spin cycle.How do i adjust the tenstion?.The belt looks fine with plenty of grooves in it.
IF you can move the drum from inside more than a few mil the bearing my be shot allowing the drun to move up and down and slackening the belt.
Posted on Sep 08, 2007
  • 139 Answers
YOU CANT THEY ARE STRECTH BELTS MOST LIKE THERE IS SOMETHING WRONG WITH YOUR DRUM. THE COMMON SIZE OF BELT FOR THESE MACHINES ARE EITHER 1153 J5 OR 1158 J5 EITHER WILL DO THE JOB BUT IM GUESSING YOUR MACHINES HAD ITS DAYS. dOES IT MAKE A UNWANTED NOISE WHEN SPINING ?
Posted on Aug 31, 2006
Speed queen washing machine fills water but does not agitate but all other cycles spin and rinse working perfect. i took out the belt and started the cycle and the motor was moving fine.
the motor spins with out the belt , makes me tend to discount the capacitor
I would be looking for a tub brake that is not being opened to allow the tub to agitate
there are solenoid activated brake under the machine the applies a brake when you lift the lid during wash, when the program is finished
have a technician check it out
Nov 10, 2015 | Speed Queen AWS44NW Top Load Washer
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Front loading LG washer WM0532HW squeeking noise as drum cannot seem to spin with clothes full of water
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Aug 15, 2010 | LG Washing Machines
How do I install a new fan belt?? 2000 Ford Nustang, 3.8
First you should make a drawing of the routing of the belt. there is an belt tenstioner which you must remove the tenstion on the belt which you can use a 3/8 ratchet. Losen the tenstion and the belt should slid off. make sure the new belt is the same size in legth and number of ribs. Spin all pullys to make sure the spin free and not making a grawling noise.
Feb 20, 2010 | 2000 Ford Mustang
Machine reads F-01 at end of cycle. Sometimes final spin cycle repeats itself several times during last minute of cycle.
F01: Aquarius and Ultima models may show this. It could be a faulty motor or motor control board. The motor tachometer could also be faulty. Some machines have a little rotating magnet and sensor, and the magnet can become detached (not sure about these though on this model). NOTE: if this code is not constant, and tending to come up during spin, check the drive belt for wear or slack, and check the motor brushes.
Jan 27, 2010 | Hotpoint Washing Machines
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
