Question about Parrot Par Ck3000 Evolution Ck3000 Handsfree Car
Cant switch off
Stays on even when car is switchted off
Sounds like the unit is connected to a circuit that stays on even when the car is off. you may need to reconnect the power wire to a circuit that fully powers off when the car is turned off.
Posted on Apr 11, 2012
How to bypass on off switch. the wire is still there but is there a way i can bypass the switch
Switcht probably provides continuity to a ground in the coil when set to off. So to stop grounding the wires do not connect at the switch. Bypass would be be simply snipping wires to switch. Now it will run always. Check it with a continuity before you do anything permanent.
Sep 14, 2015 | Electrical Supplies
E350 ran fine this morning. Parked on driveway to add rear camera. I did blow two fusses while wire up camera. one was cigettet lighter and another, Replaced both now won't start. Cranks and doesn't s
Check the starter ground wire.It might touch a hot wire.
Realize that the accessory or ignition wire stayed ground when the key is turned off.That's what will happen.Shorted wire stay constant and the key off stays grounded.Equal (Power+} and (Ground-) or check the ignition key switcht for short.
Sep 28, 2014 | Cars & Trucks
Door ajar light on 02 explorer stays on. tried the wd-40 thing and have tested all switches. still stays on
go to www.autoelectronico.com translate this web with your browser get the topic and fix it. God bless you
However you must test the bulb for short and replace, and test for short wires with switcht, the transistor, resistance, diode . see the diagram attached.
Jul 31, 2013 | 2002 Ford Explorer
Vw golf when wipers are switchted on they are very slow but they affect the lights and indicators
This is a sign of power overdrain. Check for shorted motor wiring and the motor itsels. If partially burnt it will do that.
Jan 18, 2013 | 2006 Chevrolet Trailblazer
Cant start. the power to the dash stays on even
Sounds like a bad starter switch at the column there. May need to replace that.
Mar 16, 2010 | 2001 Ford Taurus
Brake lights will not go off except when you take the fuse out
renew the switch its an easy job on these cars
Aug 22, 2009 | 1998 Ford Escort
Main beam stays on
Your Light Control Module (LCM) is faulty. It can be repaired. www.lcm-repairs.co.uk
E39 5 Series 1997-2003
Jul 24, 2009 | 1997 BMW 318
My rca
Tac switch defective. (front panel control switcht) replaced it.
Aug 04, 2008 | RCA F27442 27" TV
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Parrot Par Ck3000 Evolution Ck3000 Handsfree Car Logo
73 people viewed this question
Top Parrot Cell Phones Experts
Andrew Wright
ray gallant
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
