WD my book live 2TB not allowing access to secured folders
When attempting to access the secured folders on my WD MBL, i get a box to enter username and password but when I enter these details I get a message saying I do not have permission to access them. It woked fine this morning when I transferred some photos to one of the folders but this afternoon when trying to transfer a video file I encountered this problem. please help!
SOURCE: Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Posted on Dec 18, 2007
SASSYBEAR
  • 148 Answers
SOURCE: iomega 500 Gb external hard drive - won't allow transfer of large files
go into Device Manager and into the properties of the drive, then Power Mangement and tell Windows not to allow power to be reduced to save energy.
Posted on Mar 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Problem with transfering photos and videos to my Sandisk Sansa e26 and uploading music...HELP!
Everyone - install quicktime to get the right codecs to fix the video conversion issue
everyone else:
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
  • 12 Answers
SOURCE: Transfer videos to my sony nwz-s616f
Firstly; is it in the right format? You say MP4, but the video needs to be specifically MP4 - 320x240 screen resolution. It won't play if the resolution is incorrect.
So get that fixed up first if that's what's wrong (http://www.dvdvideosoft.com/ has a great program to convert videos to MP4). If not, sometimes my computer doesn't allow me to put files on it one way, but it will another, so try copy/paste instead of drop and drag. Hope that helps.
Posted on Oct 02, 2008
myrlex
  • 674 Answers
SOURCE: Folder on External Hard Drive showing up as empty and Access Den
you got corrup because of not properly ejecting of hdd.. okay.. try to connect again then rigth click the hdd then properties, tools, click the check now.. select all.. dont intirup it until done.. if desconnect the hdd will be damage at all..
Posted on Jun 09, 2009
Why can't I access any of the files on my WD Elements external hard drive?
If you have not reinstalled a new OS the drive should be seen after starting your unit.
Disconnect the USB drive and reboot your unit.
After the unit comes up, plug in the drive.
If the drive is new to the system, it will locate and load drivers.
Afterwards it should give the opium to view files.
It should also be seen in your device manager, under disk drive.
You should be able to go to prosperity's and see sharing opium's ect. ( Security ) Try to make your changes here
May 20, 2014 | Western Digital 2TB WD ELEMENTS USB...
Western Digital WD My Passport 2TB USB 3.0
i have one too, we are book ends, huh?
mine work great , all my toys, does yours"
Sep 26, 2013 | Western Digital WD My Passport 2TB USB 3.0...
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Not able to open my mail account
Hi Satish
YAHOO MAIL ACCESS PROBLEM
When you set up an e-mail account with free public e-mail services such as Google Mail, Hotmail/Live or Yahoo! Mail, you are invited during the setup procedure to enter an Alternat(iv)e E-Mail Address. The purpose of this is to provide an address to which the Support Team of the E-mail Service Provider can send a link or code (or both) to enable users who have forgotten their passwords to reset their passwords.
Go to the Log In/Sign In page of the e-mail account you are having problems with and click on "Forgotten Password". Enter your alternative e-mail address and then submit a Password reset request. You may also be asked some security questions in order to verify you as the account holder. Once you have accessed and opened the Yahoo e-mail sent to the alternative e-mail address, click on the link inside and you will be allowed to reset your password.
To avoid mistyped password errors, this time, before you enter the new password, type it into a text or e-mail and then copy and paste that into the password box before submitting it. Send the text or e-mail containing the password to yourself or to your other, functioning e-mail address and save this e-mail in a discreet folder on your cellphone.
Unfortunately if, for any reason, you are unable to access the alternative e-mail address or accurately answer all the security questions, then you will never be allowed access that account again, unless you can remember and enter the correct Username, Password and Security Question.
In that event, however, there is nothing to stop you opening another Yahoo! Mail account. Only the Username/E-Mail Address will have to be different.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 24, 2011 | Yahoo Mail
How can i delete skype user name from skype start up page
    • 1 Click "Start," then type "Run" in the search box. Enter "%appdata%\skype" in the "Open" text box and press "Enter" or click "OK."
    • 2 Highlight the folder in the open directory window with the Skype username you want to remove. Press the "Delete" key or right-click and select "Delete."
    • 3 Click "OK" in the confirmation window. The Skype username will no longer be in the login screen drop-down menu.
Feb 02, 2011 | Skype IM
WD My Book 1TB not recognised by belkin modem router USB storage
Hi
i am fairly certain The WD my book external hard drive needs to have the correct software to be able to use and because routers dont have a CD drive i dont think you will be able to do it.
Apr 27, 2009 | Belkin N1 Vision Wireless Router
No space error
This is due to the file transfer limitations bound by the file format FAT32 (no files larger than 4GB and no folders that contain more than 1000 files). Try formatting the drive to NTFS.
Dec 30, 2008 | Western Digital My Book Essential 1TB...
I have a world book 1tb hd with mionet. connec to network
hard drive is hanging up continually have to p[lug in and unplug in order for me to transfer everything off of it!
Dec 11, 2008 | Western Digital 500GB My Book World...
Reset password won't work
How to reset the username, password, and network settings of a WD My Book World Edition hard drive. trnsp.gif Answer The directions below detail how to reset the username and password (for the Shared Storage Manager utility), and network settings of a WD My Book World Edition hard drive by using the recovery button on the back of the unit.
  • The username will be changed to "admin"
  • The password will be changed to "123456"
  • The network settings will be changed to DHCP (obtain an IP address automatically).
    1. Please ensure that the WD My Book World Edition hard drive is turned off and all cables are disconnected from the unit.
    2. Insert a paperclip or narrow tipped pen into the recovery slot on the back of the unit. Press and hold down the recovery button.
    3. While continuing to hold down the recovery button, connect the power cable to the back of the unit.
    4. Hold the recovery button down for at least 40 seconds while the unit boots up and then release the button.
    5. The unit may take up to three minutes to boot up completely. It is only necessary to hold down the recovery button for the first 40 seconds of this boot up process.
    Note: Western Digital recommends rebooting the computer system after making any network setting changes to the WD My Book World Edition hard drive.
  • then from WD software select General Setup->WD Anywhere Access settings->Reset.
    Jan 11, 2008 | Western Digital 500GB My Book World...
    Computers & Internet Logo
    203 people viewed this question
    David Payne
    David Payne
