Hello i have a maytag gz2626gekb side by side and it has suddenly stopped making ice. the water faucet is working so there is water through the system. many thanks Lavinia
You
have two sides to the water control valve. One side is for the water coming from
fountain and the second side is to refill your ice maker after each cycle of
dumping ice into the ice bin. The freezer should be a 5 degrees or below for
the ice maker to function properly. If the ice maker is empty then fill with
tap water up to top edge of the ice maker and allow to freeze. If after the
water freezes and dumps the ice into the ice bin the ice maker does not refill
I would recommend replacing part=> 67006009 Dual Water Control
Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here
should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
SOURCE: Bottom of Maytag Freezer Ices Up
I just had the Maytag repair man out and he wanted to replace to parts after defrosting the freezer. Over $300. He did not have the parts with him. Soooo... I am now in the process of using a hair dryer, even tough it is 107 here today. Ice was totally covering the coils under the back panel in the freezer. Easy to take out. Just remove the shelves and you will see it. If you don't totally get all the ice out it will build up even faster. He claims this will give us 2 weeks or so while the parts on on order. I now have all the ice I can see removed, I just hope it is out of the tube above the coils. I have all my food, lots of good steaks, I want to put back in the freezer. The original problem seemed to be the refrigerator was not working but the freezer seemed to be. Well, it just faked me out because it was just a fan or ?? I heard in the freezer. Wish me luck...MJ
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
I need you to double check the model number. Maytag has a service library at this link. http://www.servicematters.com/maytag_library/html/index.html
By placing the first 3 letters in the search feature it will take you to models like yours. Chose the correct model that you have and enter the number in the search. I believe that the water control valve on back of your refrigerator is the problem. Maytag is very good about helping their customers. Let me know if you have problems gettting the information you need, Thanks, Sea Breeze
SOURCE: Maytag side by side freezer drain icing
This is a pretty common problem. Sometimes the defrost cycle is not long enough because the freezer setting were too low. But most times this begins slowly until the drain finally closes and then the water has no where to go but the inside of freezer or refrigerator. I have more help topics to prevent a constantly happening over and over again. But you may have a blockage down-line from the freezer. So until you can melt the ice and pour a warm solution of water and clorox in the drain and it end up in the pan below the refrigerator I will hold off on that until I hear back from you, Thanks, Sea Breeze
