Question about Acer Computers & Internet
WHEN LAPTOP IS SWITC\HED ON..IT STAYS ON THE TRAVELMAYE LOGO WITH A THIN RED LINE TO THE RIGHT AND A THIN WHITE LINE TO THE LEFT OF SC\REEN.////////IF LAPTOP IS POWERD UP WHILST HOLDING DOWN F2 BUTTON..A MESSAGE...PHOENIX BIOS ....COMES UP BUT NOTRHING HAPPENS....STILL TWO LINES ON SCREEN..SAYS ENTERING SETUP AT BOTTOM LEFT PF SCREEN...BUT THATS IT!PLEASE HELP?
    Genius:
  • 1,226 Answers
ok..enter to the bios setup and then find "load bios setup default" and then save and restart the system.
If won't help then, verify if the hard drive is detected..if don't know how to detect hard drive, go to bios set up and find hard disk if detected. if not hard disk found then ..consult your vendor for immediate support.
melnavz
Posted on Oct 23, 2008
Dell n5050 grey static screen
Sounds like the GPU has over heated and is causing video driver issues. Usually the GPU needs re balling as the solder has melted underneath the BGA chip. A specialized repair is required. Take a look on flea bay for prices.
Oct 26, 2013 | Dell Computers & Internet
Thin white line on right side of tv intermittent
The only easy hope here is centering is off just slightly to the left and the line etc will show on certain scenes and or channels.
Not sure if this set has a centering in customer menu or maybe in the tech menu---a call to sharp might answer this for you.
Aug 28, 2012 | Sharp LC-32SB24U 32 in. LCD TV
I need a wiring diagram for a pioneer deh-27mp cd player... thanks
red is 12 volt line that turns on with the key- the yellow is the 12 volt that stays on regardless of the key- the blue provides 12 volt to turn on an amp or to raise the antenna- the grey is the front right + speaker line-the grey with black right front speaker negative-white left front speaker + white/black is left front speaker negative- green is left rear speaker + green/black is left rear speaker negative purple is right rear speaker + purple/black is right rear speaker negative DO NOT GROUND THE SPEAKER NEGATIVE WIRES
Apr 10, 2011 | Car Audio & Video
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Ford focus 1999
Pin --- Color --- Stripe --- Function
Harness 1
1 --- White --- Black --- Left front +
2 --- Gray --- Black --- Left front -
3 --- White --- Purple --- Left rear +
4 --- Gray --- White --- Left rear -
5 --- White --- Red --- Right front +
6 --- Gray --- Red --- Right front -
7 --- White --- (none) --- Right rear +
8 --- Gray --- (none) --- Right rear -
Harness 2
1 --- (not used)
2 --- Black --- Green --- Radio Ground
3 --- (not used)
4 --- Orange (thin) --- Black --- Radio Illumination
5 --- Green --- Yellow --- Radio switch
6 --- Black --- Yellow --- Radio Ground
7 --- Orange (thick) --- Black --- Radio 12V
Harness 3
1 --- White --- Green --- Speed sensor
2 --- (not used)
3 --- (not used)
4 --- (not used)
5 --- (not used)
6 --- (not used)
Dec 22, 2008 | 2003 Ford Focus
1994 ford escort stereo wire colors?
1994 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
PLEASE RATE THIS INFO AS A FIXYA! IF YOU FIND IT IS WHAT YOU NEED, THANKS ALLOT.
Oct 08, 2008 | Ford Escort Cars & Trucks
Vertical lines in my laptop screen
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
Sep 19, 2008 | Dell Inspiron 1501 Notebook
Lines on screen
laptops do not have degausing thats only on rct screens what you have is a pixil problem and the lcd or plasma is in need of repair or replacement, if your laptop is under warrinety i sugjest you bring it in soon.
Sep 13, 2008 | Dell Inspiron 2200 Notebook
Wiring pinout
Mar 31, 2008 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Computers & Internet Logo
75 people viewed this question
Brian Sullivan
Brian Sullivan
