Question about Brother LS-2125 Mechanical Sewing Machine
I keep missing a stitch
While i am sewing it seems to be skipping stitches? I have adjusted everything and nothing seems to work. i have tried rethreading and nothing.. help me please
    New Friend:
  • 184 Answers
Skipping stitches can be caused by a bent or dull neeedle or a needle that is not suited for the fabric you are sewing on.
Posted on Feb 09, 2012
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
sewbuddy
SOURCE: No stitches 925D.
Probably your looper timing is off. This is common, and just a necessary evil of sergers. Their tolerances are tight.
The operation of creating a serger stitch is a succession of thread grabing and delivering. One looper grabs a thread and delivers it to the needle and so on.
To check this, turn your handwheel slowly and check to see that the upper looper is meeting the lower looper by passing very close to the indented part at the back of the lower looper (indented part is called the scarf, this is where the looper threads form a lock) If not, it's the looper timing. If they seem to meet properly then check your needle. Is your needle up into the needle clamp all the way? Try a new needle. Even a slight bend to the needle will not allow the loopers to meet and grab or deliver thread. You might check the tensions. Thread has to have some resistance in order for the loopers to do their job,
If your looper timing is off, find a sewing repair person to retime the serger. Don't try it yourself or put this repair off. If the loopers go further out of timing, they might hit something and replacement can be costly.
Posted on Nov 18, 2007
  • 69 Answers
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
Mimito7
  • 128 Answers
SOURCE: loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
Posted on May 12, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
How do I get it to sew?
was the presser foot lowered? check if the loop-taker is properly installed or seated.
Oct 03, 2015 | Brother XL2600I Sew Advance Sew Affordable...
I have a Hyundai 8 stitch sewing machine and have great difficulty sewing with it. The thread keeps bunching up underneath and misses a lot of stitches. I have followed instructions, both threading up
here is a suggestion for the skipped stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
and since it stops with a crunch,, I suggest having the machine
checked to see why that happening
Feb 18, 2013 | Sewing Machines
Machine is skipping stirches
Skipped stitches
Sep 17, 2012 | Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Skipped stitches
You will need to take your machine to a dealer and have it adjusted. Machines should be cleaned and serviced at least once a year. Needles should be replaced when dull. Skipping stitches can also be from using the wrong kind of needle. When quilting on cotton, use sharp needles, when sewing on knits use a ball needle. You can use a universal needle but they aren't perfect and will cause skipping on some fabrics.
Apr 26, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
168 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
