Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
Red green blue discolor picture
When watching tv every once in while the screen jumps to all red or green or blue
    Problem Solver:
  • 10 Answers
Convergence unit is bad
Posted on Oct 23, 2008
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
Sitting here watch tv and suddenly the picture went warped and discolored. Picture looks like the colors are seperated. blue green and red.
Your TV has convergence chips that need to be replaced by a tech. These keep tour red green and blue lights in sync with one another in order to give you a sharp color picture. When they fail your colors seperate.
Nov 07, 2010 | RCA D52W23 52" HDTV CRT TV
The screen seems to have two of the same image, green and red.
Yes.
The fix is to replace the two Convergence IC's( STK392-110's) with STK392-150's. They are located to the right side of the chassis and mounted to large heat sinks. Be also on the look out for some burnt resisters and or discolored resistors that failed becuase of the IC's failing. These would be located just to the left of the heat sinks. If they are burnt or severly discolored, you will need to replace them with the exact valued resistors. In this high current circuit it is a must.
I hope this helps,
Skyassoc
Jan 07, 2010 | Hitachi 60FX32B 60" Rear Projection...
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
A lot of red in pic no matter what we do and tint dose not change anything
As is typical with all Philips projection sets the cooling fluid has become contaminated in the blue and green picture tube assemblies. The red is almost never affected with this as whatever bacterial growth is discoloring the fluid in the blue and green tubes can't seem to survive in red light. The blue and green light is shining up through muddly cooling fluid and that is why the red is predominating. A reputable tv repair shop can pull the tube assemblies and dismantle them and clean and reassemble and refill and do all the necessary adjustments for around $300 to $400.
May 26, 2009 | Philips Televison & Video
Picture has blue,green,and red phantom lines on the screen
Sounds like a convergence problem. Are you interested in fixing this yourself? If so you will need to know how to solder well and use a meter. I can assist you as much as you need through the process. If you post a picture of what the screen looks like we can know for sure what you have going on. If you call a repairman to fix it he will charge somewhere between $300-$500 to do the repair. Let me know if you need more help!
TIm Nolan
Sep 12, 2008 | Mitsubishi WS-65869 65" Rear Projection...
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
