Question about Canon Office Equipment & Supplies
Wher to buy ITB of Canon IR 3180
I wants to buy N ew ITB OF Canon IR 3180 becouse its get breaking surface
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: hello can somebody help me about the problem of my
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
0002 The next HP fails to be detected within
the specific period of time after the HP
of the ITB is detected.
Clean the ITB back side and the drive roller
0003 The next HP is detected earlier than the
specific period of time after the HP of
The ITB is torn due to scratches, and the
sensor detects the tear as a HP by
mistake
sensor
Posted on Jun 16, 2010
I installed new toner and drums in a brand new canon IR Advanced c5035 printer and after turning back on i get this error E000075-0003
Title : E075 - 0003
Problem : The machine displayed an error code of E075 with a sub code of 0003. This indicates an error in full displacement of the ITB to the rear side.
Solution : Behind the ITB motor there is a silver bracket with two silver screws. This bracket affects the tracking of the belt. Remove the ITB motor. Loosen the two screws on the bracket and adjust the bracket 1mm at a time until the belt stops tracking off. The location of the bracket and the screws are shown below.
Canon USA, Inc. Engineering Services & Solutions Division
Jun 20, 2017 | Canon Office Equipment & Supplies
MY IR 3180 COPIER IS SHOWING E000732 0001
canon ir 2830 modal error e000732 0001 solutions
Sep 17, 2013 | World of Warcraft Doom Commander Zaakuul
Canon ir 3100 error code e000070-0001
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
May 03, 2011 | Canon iRC3100 Printer
E070
getfile.asp?rid=1258 April 12, 2007 getfile.asp?rid=3215 Product : iR6800
iR6870 Title : E070 Problem :
E070 error code.
Sensor reflectors on the inside of the ITB become dirty and do not reflect the light properly from the home position sensors.
Note* - If the equipment is not properly serviced, in regard to filters, the equipment filters can clog up and cause stray toner to build up in the ventilation area. If this occurs, there is a chance that HVT2 can become contaminated and copy quality issues will occur.
Additionally, soiling the white ITB patch may also occur causing E070 error code.
Solution :
Clean the reflective surface inside the ITB or replace ITB.
In regards to filters - Be sure ALL 6 Filters are replaced and/or cleaned at it's proper intervals. If ALL 6 filters are not addressed, poor ventilation will occur and toner can contaminate HVT2. If contamination of HVT2 happens replace HVT2.
HVT2 = FM2-0528-000
ITB = FC5-1658-000 Canon USA, Inc. Systems & Technical Support Division
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Hello can somebody help me about the problem of my machine canon ir 3180 CI when i make a multiple copy theres an error code appear E000070-001 please help me guys
sensor
mistake
sensor
Apr 06, 2010 | Canon iRC3100 Printer
Canon IR C3200 Out of registration. When i print out a test print the colors are all out of sink and not lining up on top of one another. was running fine and then it started having this problem
the cause of the problem is ,the transfer belt is not rotating properly ITB rollers must cleaned throroughly (cleaned by isopropyl alcohol) to prevent slippage of transfer belt that causes mis alignment /misregistration of color,but copying BW is ok,In other words ITB unit needs servicing
Jul 16, 2009 | Canon Office Equipment & Supplies
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
Irc 3100 e070-001
try to check the grounding plate did not come in contact with the shaft of the ITB
drive roller in the ITB unit, causing a poor ground (1 case). This grounding plate is used to establish a ground for
the ITB tension roller to the ITB drive roller.
E070-0003 can be displayed when the time that passes between the first detection of the ITB home position (HP)
and the next HP detection is shorter than a specific period of time.
Field Remedy
Follow the steps below:
1. Make sure that the inner surface of the ITB has stains or scratches on it.
2. Make sure that the ITB-HP sensor (PS19) operates normally.
3. Make sure that the grounding plate properly comes in contact with the shaft of the ITB drive roller.
Dec 06, 2008 | Canon imageRunner C3100N Copier
Canon ir-c3100 copier error code
The ITB or Intermediat Transfer Belt is slipping or not being driven properly. It is NOT fun to take out, particularly if you have a finisher attached. If you have proffessional experience with copiers and are really determined, let me know and I may be able to set you up with a manual. Otherwise, call a pro.
Jul 26, 2008 | Office Equipment & Supplies
Driver usb edimax ew-7318USg
please I need to driver edimax usb ew 7318USg becouse Im lost instal CD thenx George
Jul 02, 2008 | Edimax WRLS ADAPT| USB EW-7317UHG RT...
18 people viewed this question
old marine
old marine
