Question about Sharp EL-1197P Calculator
How to remove E message from Sharp Calculator
After changing the paper, the calculator will not work. It keeps showing an E message.
ginko
  • 19396 Answers
SOURCE: Sharp EL-1801V Calculator
The manual for 1801v is not distributed from Sharp anymore.
You can download the manual for EL-1801PIII Operation Manual (240K) , It is the same model with some cosmetic difference.
Regards
Posted on Apr 02, 2008
SOURCE: need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Posted on Mar 13, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
  • 102366 Answers
SOURCE: how do i put paper into my calculator?
Follow the illustrated instructions in the manual you can download here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Posted on Mar 12, 2010
Jimsta01
  • 405 Answers
SOURCE: how to change date and time
Found Instructions for EL-1197PIII Calculator, think its the same thing
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 07, 2010
My SHarp calculator shows a "P E" message and quits working. Can this be shut off so I can use the calculator?
From a Sharp Printing Calculator manual
When the paper jams, the printer stops and the error symbol
"P.E" appears. Turn off the calculator. Tear off the paper tape
and then pull the remaining part of the paper forward and
completely out of the printer
http://www.sharp.se/cps/rde/xbcr/documents/documents/om/30_cal/EL1611P_OM_GB.pdf
Feb 14, 2017 | Sharp Office Equipment & Supplies
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Sharp calculator
Is it possible there is paper stuck in it?
Aug 15, 2014 | Sharp EL-1197P Calculator
We have a SHARP EL-2196BL printing calculator, but no user manual. We can't get it to print the answer when we are adding. It shows on the screen, but not the paper. Also, it just keeps adding up...
You can download the manual from the manufacturer's web site at
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL2196BL.pdf
Feb 26, 2011 | Sharp EL-2196BL Calculator
I've been trying to load paper in my calculator but it won't feed. What am I doing wrong?
if the paper feed roller is rotating clean the roller and change the paper, please be careful the print mechnism is frigile if it persist change the mechanism
Aug 27, 2010 | Sharp EL-1801P Calculator
Jun 23, 2009 | Sharp EL-1801P Calculator
The calculator keeps displaying a P with a small e
You have to remove the paper roll. See also the manual: www.sharpusa.com/files/cal_man_el1611P-pdf
Apr 01, 2009 | Sharp EL-1611P Calculator
Calculator paper roll change, How to?
feed paper throught bottom to top hold down paper feed botton
Jan 26, 2009 | Sharp EL-1801P Calculator
How do I replace the printer paper in my sharp EL-1192BL calculator
Feed the paper into a VERY thin slot on the back side of the calculator. This thin slot is below the removable clear plastic paper guide and is very inconspicuous.
Apr 10, 2008 | Sharp EL-2196BL Calculator
Paper not moving forward
please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
Sep 18, 2007 | Sharp EL-2630P Calculator
Sharp EL-1197P Calculator Logo
180 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
