Recently, This DVR finds fewer and fewer discs acceptable. It will play Side 1 of Schindlers List beautifully, but will not recognize Side 2. Same for many movies I recorded on it previously and had played well. Now it cannot even recognize blank discs for recording. Some movies I buy it will read, but most not. On occasion I can hear a shutter or gring when I insert a DVD. Help?
This is a tough one that CAN be solved. You will have to take the DVD Drive out of the unit. Take the drive apart and grease yes grease the rails the laser slides back and forth on. I used regualar Vasoline as it is inert and lasts forever. The sound you are probebly hearing is the stepper motor trying to move the stuck laser. I had the same problem. Or you could replace the entire drive, but as it doesnot work now you are not out anything trying to grease the rails because it is already broke. Take it slow and remember where everything goes. This is assuming that you have parked a cleaning disk in it already.
the 90% of this problem are sove with a cleaning cd but I asume that you already do it then try with dry air(buy a can in radio shack) blow dry air by the port of the dvd with the tray open if not you have to take the machine to a tech...you got problem with the reading eyes...good luck
My TruTech DVD recorder went the same way, I returned/exchanged it twice and finally gave up and bought something of better quality. Sadly this seems to be typical of TruTech products.
i have a panasonic dmr-hs2 dvd recorder but its settings are in japanese,how can i change them to...
(More)
i have a panasonic dmr-hs2 dvd recorder but its settings are in japanese,how can i change them to english?
I have a similar problem. I'm thinking that I may need to buy an RF converter and try hooking it up...
(More)
I have a similar problem. I'm thinking that I may need to buy an RF converter and try hooking it up through that. I'll let you know if that solves the problem.
I keep getting this message after a recording has completed; at first it was very occasional, but...
(More)
I keep getting this message after a recording has completed; at first it was very occasional, but now it is a persistent and seemingly permanent problem. How do I (or my local repairer) fix it? Noel Stimson Isle of Wight, England
I have a Lenovo 3000 N200 type 0769 and would love it if it would play other regions of dvd's any...
(More)
I have a Lenovo 3000 N200 type 0769 and would love it if it would play other regions of dvd's any ideas, Cheers, Veronica
I bought a used panasonic Dmr e 20 from a neighbor. (I was that it worked at his house.) I've...
(More)
I bought a used panasonic Dmr e 20 from a neighbor. (I was that it worked at his house.) I've connected it to my Sony TV and programmed the remote so I can turn the TV and DVR both on and off. The cable runs into a TIVO, then TIVO output to the DVR input, and then from the DVR output to the TV input. I pressed play on the DVR but the TV won't swith over from TV to the DVR.
