Question about Stihl Saws
My stihl saw ts400 start gran when cold but when you stop it and try to start it agin it wont start untill it cool's down and then it start ok
  • 4 Answers
Clean the air filter and check that the choke is operating correctly.
Posted on Mar 04, 2013
5 Suggested Answers
  • 623 Answers
SOURCE: I bought a rebuild kit for a Stihl TS400 and the
I believe the arrow must be installed facing the exhaust.
Posted on Jun 07, 2010
  • 26 Answers
SOURCE: stihl ts400 will not stop, it carries on running
Stihl guards their service manuals making them only available to dealers who service Stihl.the kill switch is not making contact. a t25 torx should get you to the point where you can determine if my theory is correct.
Posted on Feb 27, 2010
  • 111 Answers
SOURCE: need to know belt size fo the stihl ts400 concrete
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Posted on Mar 30, 2011
H2_Brad
  • 425 Answers
SOURCE: Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Posted on Jul 18, 2011
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Starting ts410
This might be an ignition problem... Try setting in new fuel if that doesn't work take it to the shop.
Nov 21, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Ts400 hard starting
Check the fuel tank vent, it could be creating a vapour lock in the fuel tank
Nov 05, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl ts400 runs rich and wont idle
Sounds like it is leaking on the inlet needle, a pressure test of the carb will quickly tell you this, the needle will have a rubber tip, if dust has gone through the carb the needle seat may be worn, the needle is replacable unfortunatly the seat is not, the metering lever is also adjustable, if it is set too high the needle will leak, it is also important that on the metring side the gasket goes on first followed by the diaphram, the gasket acts as a spacer, the metering lever should be level with the sides of the carb body, if too high simply bend it down, if the metring lever is high this is a good sign the rubber tip of the needle is worn.
Feb 04, 2013 | Stihl Concrete Cutoff Chop Saw Clutch...
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
I have a stihl st400 disc cutter & I think the pull start needs cleaning, any advice?
compressed air works well. you really need a gun with a long skinny nozzle. for example
Jan 26, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Need to know belt size fo the stihl ts400 concrete cutoff saw
Aug 31, 2010 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Mar 24, 2010 | Oregon Scientific Complete Carburetor for...
Saws Logo
397 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
