Question about Texas Instruments TI-Nspire Graphic Calculator
How to close tabs on ti-nspire - Texas Instruments TI-Nspire Graphic Calculator
  • 4 Answers
SOURCE: Can keypads only for the ti-nspire be purchased?
http://epsstore.ti.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11092&item=76072&JServSessionIdrootdlek22=umke2gv3m1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--
Posted on Jan 25, 2009
SOURCE: TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Posted on Nov 25, 2009
  • 7993 Answers
SOURCE: TI-Nspire 84 Plus keypad problem
Remove the TI84 Keyboard, insert the TI-Nspire keyboard and try to reset the calculator with a starightened paper clip.Calculator has a reset button on the back.
Posted on Feb 01, 2010
  • 24 Answers
SOURCE: I have issues turning on my TI-Nspire using TI-84 Plus SE keypad
i would say use the normal key pad or send it in to T.I to fix.
Posted on Mar 12, 2010
  • 12 Answers
SOURCE: I downgraded my TI-Nspire's OS
I had this same problem myself and I had to look everywhere to find a solution. You will have to remove the current OS from your device. Heres how.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=101985&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC81E19298A9321E38D51491551F331C8CCDA6801E50CC672F84B3EFDF0F6ACEF9DD42026E6C2FF1F9579670CF87CEAF79D
I couldnt use option 2 for some reason and had to use option 4 (complete format, luckily I had backed the files up earlier) but once it was reformatted the device showed up in the software and told me to update the OS. From here you just install the latest OS as you would normally.
The problem with what you and I did is that previous OS versions (1.7 in my case) dont support the keypad, you may be able to use the older version with a different keypad but I'm not sure.
Anyway, I hope you can fix it, good luck.
Posted on Jan 08, 2011
My TI-nspire cx cas calculator says operating system not found. Install OS now. Can someone fix this problem?
Have the TiNspire Computer Link installed on your computer.
Download the OS from from education.ti.com
Connect your calculator to the computer with TINspire Computer Link. Run the software. It opens an explore type window. Under the TOOLS tab find Install OS. If it does not connect to the Internet, point the software to where you stored the downloaded OS.
Sep 29, 2015 | Texas Instruments TI-Nspire CX Graphing...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
I am own a Ti-nspire and trying to download the latest Ti-84 silver plus os however when it begins to transfer to my calculator it says transfer error what can i do to fix this?
The standalone version of the OS for the TI84Plus/TI84Plus SE are not for TI-Nspire with TI84 keyboard. The 94 Plus part of the TI-Nspire is updated when you update the OS of the TI-Nspire. The version numbers are different.
To update you TI84 portion of the TI-Nspire, update the OS for the TI-Nspire. Thy are now at Version 3.2.3.1233
Sep 26, 2013 | Texas Instruments TI-Nspire Graphic...
Os transferring error
Sep 26, 2013 | Texas Instruments TI-84 Plus Silver...
How do I set up my TI-nspire to show a large answer in scientific notation?
In OS 3.x Press 5:Settings>2;Settings>1:General.
In the screen that opens, use TAB repeatedly until you
reach the line : Calcul Mode. Use right arrow to open
that menu. Select the option APPROXIMATE and press
ENTER. Use the TAB to move the highlight on the OK
button and Press ENTER/OK to save the changes.
All large values will be displayed in Scientific Notation.
Aug 30, 2011 | Texas Instruments TI-Nspire Graphic...
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
Ti 84 nspire,replaced batteries and now it says "operating system not found,install OS" Of course my son has a finals exam tomorrow..help!!
Hi
A. Download the TINspire OS from education.ti.com
Use the Ti-Nspire computer link to reload the OS onto the calculator.
  1. Remove the Ti84 keyboard and insert the Ti-Nspire keyboard.
  2. Make sure the battery are good.
  3. Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable
  4. Run the Ti-Nspire computer link software.
  5. The select device dialog should appear, and detect the device.
  6. With the mouse cursor, select the OS, drag it and drop it on the main window (file browser window) of the TI-Nspire computer link software.
  7. Alternatively, click the menu Tools and select Install OS. A Select file window opens.Use the browse button to point to the OS and click Open/OK
B Installing from another Ti-Nspire ( not a TI-Nspire CAS) if availabe)
  1. Connect the two devices using the USB Mini A to Mini B cable
  2. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
  3. Both units must be turned ON
  4. On the sending unit, access the document chooser by pressing [Home](the house icon).
  5. Once in the document chooser, press [Menu] and choose 9:Send OS…
Hope it helps.
Thank you for rating the solution.
Dec 11, 2009 | Texas Instruments TI-84 Plus Calculator
My TI Nspie CAS calculator is restarting frequently
If you remove battery door, the TINspire CAS cannot be turned ON.
You may try to reset the unit by pressing the reset button on the back of the unit. If that does not solve the problem, you may try to reinstall or update the OS.
Anyway, here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Hope it helps.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Oct 08, 2009 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Deleted OS
Here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Please read it till the end.
Mar 23, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
375 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
