Question about LG WD-3274RHD Front Load Washer / Dryer
Retro-fit drain hose
I ordered a new front gasket (boot - the rubber piece that seals the door and the tub) for my LG WD-3274RHD, the new one that arrived was perfect, with the exception that there is now a drain hole in the front. This was a retro-fit fix to stop the problem of water pooling and sitting inside the gasket just inside the door. Great idea, however where do I drain it to!! Lots of calls to LG and yes there has been a change but nobody can tell me where to drain it to, and where to get the retro-fit kit. I think I can likely splice into the drain hose that runs down from the right side of the washer into the impeller on the bottom left, however I don't want to start cutting hoses in case this has an effect on how the pump works etc.. Another solution is to get a drain plug and just plug it off, however I like the idea of draining that part of the washer so water doesn't sit and start to smell...
Has anyone done this retro-fit? Thanks so much, Rob (rob . mctavish @ gmail . com)
  • robmctavish Oct 23, 2008
    HI there, I've posted the instructions online at: http://www.sfu.ca/~mctavish/00411534.JPG the drain doesn't drain into the tub, it is meant to drain into a hose, but where does that hose drain to... It is used in my suite and my tenant doesn't always wipe it out I believe.... Thanks for your help, Rob
    I know I could get a connector, a hose, and a Y connector and attach a hose to the drain then put a Y into the drain hose that comes down the front, but I don't know what that hose does exactly, if the impeller gets too much water due to my new attachment will that stop it from working, or is there any vacuum as in a sealed system that I would mess up... all questions for LG to answer... I'm waiting for a call back from them. I've spoke to numerous agents and only one (Carlo in Canada) knew what he was talking about, unfortunately the parts place he sent me to didn't know what I was talking about and I can't get back in touch with him. Being 3 hours ahead of the call centre doesn't help either. Thanks for your help, maybe someone out there has done this and knows. Rob
  • 566 Answers
Hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Posted on Oct 22, 2008
  • silver top Oct 23, 2008
    thanks for update and pictures? i can see the mystery of drain to where?? you explained my thought on problem now would be as you suggest re connecting to drum to pump hose ? but as you mention that this has been an update on front gasket seal which incorporates the drain hole ? i am wondering if this modification kit should also involve a replacement drain hose drum to pump ? and comes with a fitted/molded piece in it for attaching a small bore hose from seal drain to it? worth checking out b4 you diy your idea on the same lines ?
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
MAH550BWW front load Maytag washer-gasket drainis clogged
There is a 2" L shape hose connected to that drain hole under. You can unclog it using a soft plastic stick. Stick it on to that hole do not force it turn the plastic stick while putting it in. Thare are 2 types of door gasket on that model one has hole in it and the other doesn't. If your original doesn't have a hole, the one that has a hole will work but there is a plug on to that hole.
This is your door gasket
https://www.rcappliancepartsimages.com/dbimages/00003022/00909166.jpg
Just take the front panell off to see if there's a small hose connected to the gasket drain hole. You can even clean it after taking the panell off
https://www.youtube.com/watch?v=6O6d3KFIfWo
Nov 22, 2017 | Maytag Neptune MAH5500B Front Load Washer
Very unpleasant odor in LG front-loading washing machine.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@!!
Jan 27, 2010 | LG WM-2277HW Front Load Washer
Beko sma 510 washing machine clothes smell when cycle is finished
Oct 16, 2009 | Washing Machines
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG WD-3274RHD Front Load Washer / Dryer Logo
356 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
