Question about Brother CS-6000
Need brother needles for sewing machine - Brother CS-6000
  • 526 Answers
The part # for the needle set is XC8834021 ,the cost will be $6.50 + shipping.
if you can not find it you can check with us.
thank you adi
Posted on May 07, 2009
SOURCE: My brother sewing machine jams threads under the
hi there, why is it that i can't sew at all..both thread are not working instead eating each other thread under....but i have a good brother ls 2125. ty...
Posted on Mar 19, 2009
  • 37 Answers
SOURCE: MACHINE RUNS BS2450 BROTHER SEWING MACHINE BUT
I'm wondering if the bobbin spool is set to wind? Or the clutch is disengaged (older models).
Posted on Jun 05, 2009
  • 980 Answers
SOURCE: brother sewing machine circuit board is out need new one
If you have any problems with sewing machines with electronic boards or if the machine is computerised it is wise to take it to a specialist for repair.
Posted on Nov 04, 2009
DianeB715
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part). The above info that was previously posted was almost dead on for me. The screw spoken about is called a set screw, which is a screw that is almost hollow. To lossen or tighten a set screw you use an allen wrench. The one on this machine is 5/64 th size. You can use a very small screwdriver if it fits tightly, but you must be careful not to strip the inside of the screw.
Posted on Dec 20, 2009
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
I couldn't find the Brother XL-3520, so I'll just ask here. I noticed that I have a single needle (already attached to machine) and a double needle attachment but I need a thicker needle for...
most domestic sewing machines use 130/705h system needles - buy a pack each of size 70, 80, 90 and 100 to start. if you plan on sewing knits (stretchy) fabrics then buy a couple packs of ball points in size 70 and 80. put in a new needle for each garment you sew as a needle goes blunt in about 6 hours depending on what you are stitching. visit www.sewing.about.com and check out sewing machines 101 and debbie's article on sm needles for more good info. depending on what your heavier weight fabric is you may need to use a 110 size to handle it. the denser the fabric the bigger it needs to be.
May 17, 2011 | Brother XL-3510 Mechanical Sewing Machine
The needle on my Brother BC-1000 Computerized machine bent while I was sewing a project. What should I do? I can't sew with it. Do I need to find a replacement needle? If so, where? Can I replace the...
You can replace a sewing machine needle on your own. You can purchase needles online or at your local craft/sewing store. They will hopefully have a section there with sewing machines that they will then be able to show you, easily, how to replace the needle, because they're all pretty much the same. You can also check out this YouTube video http://www.youtube.com/watch?v=BqBvGxzKwv0. It goes through the basic steps and should give you what you need in case you're ordering replacement needles online. You can get them at Joann's (do a google search) and just order regular, everyday machine sewing needles-you don't need special ones.
May 08, 2011 | Brother BC-1000 Computerized Sewing...
The machine needle broke and I'm not sure what needle I need for my Brother LS-2220 sewing machine
Wow, talk about rambling solutions to a simple question ...
Brooklyn35, go to a place that sells sewing machine needles and buy some, period, end of story. All home sewing machines for the last 50 years (not sergers) take the same needles, the best quality needles are Schmetz brand, they are stronger, sew better, and last longer than cheap ones.
Oct 31, 2010 | Brother LS-2220 Mechanical Sewing Machine
Where can I find new needles? (LS-2125 Machine) All my needles broke and I can't seem to find out where to get replacement ones before Halloween! Can I use any machine needles or do they have to be...
If in the uk, any high street sewing shop that sells brother machines will help you, otherwise, check the local yellow pages for sewing machine suppliers and spares.
Oct 25, 2009 | Brother LS-2125 Mechanical Sewing Machine
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-6000 Logo
96 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
