Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Kitchen spray not working completely.
My kitchen faucet (2400 series) side sprayer doesn't shut off the spout completely, when engaged. Water still comes out of both, when using the sprayer.
  • Anonymous Mar 14, 2014
    diversion value not working
    Scholar:
  • 68 Answers
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Posted on Dec 09, 2008
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Faust sprayer doesn't work
The problem is probably in the floating valve that is located under the spout. This valve floats up and into the base of the faucet when you push the handle on the sprayer to use it. This redirects the water to the sprayer.
They get stuck and then don't close off the spout properly
Short of teraring the faucet clean apart they are almost impossible to fix. Turning the water off and disconnecting the supply hoses, then blowing air back through the faucet spout may dislodge whatever is in there. This has worked for me in the past... and it has not work also...
May be worth a try..
Heatman101
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Side sprayer won't spray
THe diverter inside of the faucet is malfuncting. Remove and replace the diverter valve. It is located right under the spout assemble.
Mar 25, 2009 | Kohler K-10416-BN Fort½ Single Control...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
894 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
