Question about Ignition System for Saturn L-Series
I have a 96 saturn SL2.. one morning key wouldnt turn.. took ignition cyclinder out within 20mins.. been trying to put new one in for 2 days! What am I doing wrong
    Problem Solver:
  • 8 Answers
Insert key into new cylinder.Rotate key counter clockwise inside cylinder. install. If problem still exists, try turning clockwise to different position
Posted on Feb 22, 2012
97 Saturn sl2 will a 96 sl2' ignition run the car if yes please show how to hook it all up
Unplug the plugs and buy a used steering colum , with key , quickest easiest
Jul 03, 2016 | Saturn Cars & Trucks
I have a 1991 Saturn SL2 (SOHC) that I'm trying to get going. Replaced most of the fuel system which is good now. Tried to start and got a click sound. I assumed it was the starter. Took the starter off...
The SL2 is a DOHC, the SL1 is a SOHC. You have put more money into it already than it is worth. Seems like a free check of the crankshaft being locked up might have been a first move before expending money. There were several small improvements made to the Saturn after 91, the fist year. I would suggest looking around for a 95 where your new parts will still swap in, possibly even a 96. You can get one for less than $500 if you look around. Stay away from automatic transmissions in Saturns.
Sep 27, 2010 | 1991 Saturn SL2
Have 2000 saturn sl1 replace cyl and keys in
try putting the shifter in N and move the pressure off the wheel.
Jun 05, 2009 | 2002 Saturn Sl
1996 Saturn won't start- engine turns over
OK I don't know if this is your problem but my 92 sl2 is kinda the same way. my sl2s ECTS went out and it dose the same this is what it looks like4c01145.jpg you will have to remove the air duct to get to it and this is were it's located keep in mind there are two of them you want to unplug the one with two wires it is lower on the block. but do not remove it.
after unpluging it try starting your car if it starts them you will have to get a new ECTS Coolant Temp Sensor. btw don't drive around with it unpluged just becouse it runs dosen't mean you should use it like that.
Jan 21, 2009 | 1992 Saturn SL2
98 saturn sl2 won't start
if all it does is click with a new battery it is not the alternator because all the alternator does is charge the battery i would take the starter or selinoid off if it isnt built in with the starter and have it tested the same as you did the battery
Jan 03, 2009 | Saturn SL2 Cars & Trucks
96 saturn sl2 won't start
Not enough information.Need to know if the engine CRANKS,or turns over,just won't start up and run,or if when you turn the ignition key,nothing happens at all.If the engine cranks and turns over,just won't run,you have to check for fuel supply and spark to the spark plugs.If nothing happens at all when turning the key,could be a bad starter,battery,alternator,PRNDL switch.
Jul 08, 2008 | 1992 Saturn SL2
1996 saturn sl2
The fan wiring harness are known to be trouble. On my 96 2 dr coupe I bypassed the harness installing new wires with a switch to my dash. I'm now in control .
Jun 22, 2008 | 1996 Saturn SL
Ignition System for Saturn L-Series Logo
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
