Question about 3100L 1way Security System
My avital will not disarm what do i do
Ford taurus 2000 the alarm just wont disarm what do I do
    New Friend:
You need to find the valet button that the installer SHOULD HAVE installed somewhere in your vehicle. From there, you need to push it the number of times the installer set it to, before turning the key to start the car (default is usually 1 push, pause, 1 push). Check your owners manual, as there's a spot for installer's to write all this info in as they're installing.
Posted on Apr 22, 2013
2 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
logosc75
  • 625 Answers
SOURCE: what does the brown shutdown wire on avital 2001 ford taurus connect to
The brown shutdown wire on Directed Electronics remote starters connect the switched positive side of the foot brake. You step on the brake, the remote starter shuts down.
Posted on Aug 15, 2012
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
My security system won't disarm on my 1999 chevy blazer
Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
Aug 16, 2012 | Vehicle Parts & Accessories
I have a problem with my avital 4103 remote starter everytime i try to start try to start my car my car alarm goes off
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Feb 24, 2011 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I had a remote starter installed in a 2008 Honda Accord. When I press the button to start the car, the alarm goes off. How can I stop this?
The factory alarm needs to be disarmed prior to remote starting the vehicle. You could either add a data door lock module (HODL5) to the 4113LX to disarm the alarm or, you could extend the light green with black from the 4113 and run the wire into the drivers door and connect to the brown at the power window master switch. Test this wire while turning the key in the door.
Jan 20, 2011 | 4113LX 1Button Remote Start System with...
I am trying to install a new battery on my 2000 ford taurus and when connecting the negative the horn starts blowing and wont stop and the car wont start
when the horn starts to honk just put the key in the ignition and turn the car to on, you can also use the key to lock and unlock the drivers door, you are activating the security system by disconnecting the battery doing the above disarms it, if it still won't disarm then you need to see the dealer on this problem
Dec 03, 2010 | 2000 Ford Taurus
Horn sounds while driving on 02 taurus
you might want to check with your installer, this vehicle may have a factory alarm, which will need to be wired into the avital unit to properly disarm. Also if you didnt hook up the ignition circuit, this could cause the alarm to never see the ignition on, and will rearm itself while driving.
Aug 10, 2010 | 831002/4100 4100 REMOTE START SYSTEM WITH...
How do I disarm anti theft on 2000 ford taurus
You can't the key has a chip inside it with out it the car will not start.
Jan 14, 2010 | 2000 Ford Taurus
3100L 1way Security System Logo
260 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
