Question about ASUS Computers & Internet
My asus laptop won't turn on and so I have it
  • Anonymous Mar 29, 2014
    Plug in power pack and charge light came on for about 30 seconds then went out. Won't charge or boot. Charger ok. 19 vdc
  • 355 Answers
May be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Posted on Feb 08, 2012
  • 6 Answers
SOURCE: asus 1005HA pc not charging.. The
I have a total of 5, yes 5 netbooks and a laptop. My experience has taught me that sometimes, it is the charger not the actual netbook/notebook that is the problem. My barely used compaq laptop sat quiet for 2 years.... wouldn't charge..... I assumed it needed repairs more than I could afford. Meanwhile, with 2 of the netbooks, they stopped taking a charge even with the lil led light on. I ordered new chargers for netbooks- PRESTO-- they took a charge. And eventually got a new charger for the expensive paperweight I had too. Now they are all working again. Not an expert by any means, but have had a lot of experience with them. I would rather pay 15 bucks and be wrong, than assume it's something else- have them fix for 80.
Posted on Mar 24, 2011
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
  • 569 Answers
SOURCE: dell insprion laptop not charging the battery,
Most likely problem is a faulty charger board. A replacement, part number 48.4W006.021, can be purchased, but requires disassembly of the laptop down to removal of the motherboard. This is not difficult if you have some basic skills. Service manual describing procedure is at http://support.euro.dell.com/support/edocs/systems/ins1526/en/SM/index.htm
This is a common problem with this laptop.
Posted on Dec 08, 2009
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Aug 15, 2012 | ASUS Computers & Internet
ASUS netbook 1005 HA charger won't stay in to keep charging battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 08, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My acer extensa 5620z does not charge nor works connected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 25, 2012 | Acer Extensa 5620 Notebook PC
My ASUS P4T533-C won't turn on
This is really a common problem with computers these days. It may be caused by a number of reasons like a faulty charging system, faulty battery or anything burned out on the computer's system board. But in this scenario, i would suggest the following
1. Remove the battery and connect the laptop with the AC adapter only and see if it will respond.
2. Remove the AC and re-connect the battery and try to turn it on
3. If the above two do not work, then consider changing the AC adapter for your laptop. You can try to use a different AC adapter that has the same rating as your laptop's. The problem might be with the Charger.
4. But if all this does'nt work, consider getting a Computer Technician who can open up your computer and check the circuit board, there might be a problem with one of the chips
Mar 01, 2012 | ASUS Computers & Internet
I fully charged my asus laptop but when i took charger out the whole thing wouldn't turn on. I just got it back from repairs with a faulty charger he replaced it but gave me a toshiba charger with asus...
Hi
This can be a problem. because the new charger may keep your laptop on. But will not charge the batteries due to the fact that the voltage and amperes need to be correct too. Check in windows if it shows if the battery is getting charged if not then you have to use the same rating charger in order to avoid the big damage later.
DO RATE MY SOLUTION
Jun 29, 2011 | ASUS X51L-X2 Notebook
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
My laptop charge wont charge my laptop
is there charging indicator light on ....... check battery maybe its dry
May 30, 2011 | ASUS Eee PC 1000, 1000H, 1000HA, 1000HD,...
Computers & Internet Logo
438 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
