Question about Cell Phones
Kyocera m1000 screen went white
I have a kyocera m1000 and its not insured the screen went blank its just all white theres no cracks on the screen theres no damage to the phone it just turn white i was woundering if anyone had any idea what i can do or any tips please help thanx
  • 3 more comments
  • Anonymous Nov 18, 2008
    screen turned white, now wont turn on....any fix?
  • Anonymous Jan 20, 2009
    My inside screen just turned white one day, no cracks no scratches no nothing but i can still use the phone
  • dangit5 Feb 28, 2009
    Just one day it happened, the inner screen went white. And its less than 6 months old. WTF!
  • xrikux69 Apr 06, 2009
    My Samsung phone's screen turned white after removing it from the charger after becoming fully charged. Now, I have removed the battery, turned it off and on multiple times, and it still won't work. No scratches in the screen, it's perfectly intact. I even tried to put it back on the charger and turning it off and on while it was on the charger, still nothing.
  • imalucky1 Apr 26, 2009
    4 months old and the screen went white. Big dissappointment. Will not respond at all now.
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
SOURCE: kyocera m1000
you can email rngtones and picture at least to your phone.
the adress is (youphonenumber)@mms.mycricket.com
Posted on Mar 27, 2008
SOURCE: samsung e900 white screen
There are two possible problems and two fixes for this white screen.
First it could be a damaged ribbon connecting your screen to the handset. This is the most common reason for the white screen.
You can buy ribbons and attempt the repair yourself (instructions are available on the net) or you can take it to a shop and they will fix it for you.
Second possible cause (which happened to me when my phone fell in the toilet) the firmware on your phone has been damaged.
Again this can be fixed by yourself (info available on the net) with the right tools (the option i used) or again a repair shop will fix it for you.
Either way your phone is not broken, just damaged and can be fixed.
Posted on May 09, 2008
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Posted on Dec 14, 2008
SOURCE: kyocera oyster screen blank
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Posted on Jan 03, 2009
My kyocera loft screen went black and stayed like that. i can turn it on, take pics and all that bt its just blank
Your screen is either cracked or broken or the wires got detached on the inside. Take to a cell phone repair shop or look for a new screen on tha internet and try to fix it yourself but I wouldnt recommend that!
Aug 08, 2010 | Cell Phones
Tip
I have a kyocera m1000 and it works fine but one day the screen went white i...
HOW To format your phone first press *,3 and the call button when your phone is turn off now turn it on and it will automatically be formatted
on Oct 22, 2008 | Nokia 6100
42" samsung plasma screen cracking on
i would say take it to your local tv repair shop the screen will have to be replaced or if you told your insurance i happened because of a lighting storm they might have replaced it
Aug 08, 2009 | Vision HDV-42P2 Television
Looking for the unlockimg code for kyocera m1000-2j0
The service provider will in most cases unlock the phone for you. contact them first.
If they wont unlock it for you, get it unlocked at a website like thishttp://globalunlock.com/phones/home
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | Kyocera Car Charger For Lingo M1000, Wild...
White Screen. -_-;
well i had the sameproblem but just go to the store and find out wats wrong the soft ware has a problem but they repaired mine for cheap
Aug 27, 2008 | Kyocera Switchback KX21 Cellular Phone
Change nmber
It appears that the Kyocera m1000 is a CDMA phone and thus would not be compatible with the ATT/Cingular network that is GSM (uses a SIM card and CDMA doesn't). If though your Kyocera is a GSM phone? You would have to take your SIM card and insert it into the M1000 and as long as the phone is unlocked or locked to Cingular/ATT it will work.
May 16, 2008 | Cell Phones
Blank screen on kyocera cell phone
May 01, 2008 | Kyocera Oystr KX9 Cellular Phone
Kyocera m1000
I cant download games either but i found tons of ringtones at ringtone-mania.com!
Feb 14, 2008 | Cell Phones
Cell Phones Logo
286 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
