Question about Savin Office Equipment & Supplies
Waste toner is almost full on Savin C9020 - Savin Office Equipment & Supplies
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Posted on Aug 30, 2012
EmmettPinger
  • 63 Answers
SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Posted on May 01, 2009
  • 117 Answers
SOURCE: error c7990 waste toner full
Open the left door.remove the waste toner bottle.It is whitish, odd shaped and directly in the front.throw it in the trash carefully.replace it with a new one.close the door.Good luck!
Posted on Apr 02, 2009
  • 990 Answers
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
Posted on Apr 10, 2009
shoeria
  • 40 Answers
SOURCE: Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
Posted on Jul 09, 2009
SOURCE: Xerox workcentre 265 waste toner full msg
Clean the sensor where the waste toner bottle goes in and just turn the copier off for a couple of minutes then turn it back on. The system needs to reset.
Posted on Oct 20, 2009
What is error code sc565?
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Jun 25, 2016 | Ricoh Compatible 4 Color Set Aficio MP...
How to fix colour position in ricoh c2050
tthe machine can do autocalibrattion,
see the video
Oct 05, 2015 | Ricoh Compatible 4 Color Set Aficio MP...
Savin 2406wd how to change waste toner bottle
Do not attempt this , call a qualified tech, the drum can easily be damaged during this operation
Aug 14, 2014 | Savin Office Equipment & Supplies
I have an error on my gestetner mp c2030 with code sc222, please help me.
Problem with the yellow laser unit. Probably need a tech for that one.
May 20, 2014 | Ricoh Compatible 4 Color Set Aficio MP...
Where is the waste toner on savin 4051 sp
it's behind the front cover - lower right side...unlock the push/pull snap and side the bottle holder & bottle out of the front of machine. empty and reinstall.
Apr 08, 2014 | Savin 4051 Sp, Ricoh 2051 Sp, Copier W/net...
2030 sc573 code
IT TELLS YOU THE TERMISTOR HAD TO BE REPLACED & LATER YOU TO HAD TO RESET THE MACHINE
Sep 14, 2013 | Ricoh Compatible 4 Color Set Aficio MP...
Where is the run off waste on the Savin 9013?
If you open the right side door of the copier as if you are taking a paper jam out. On the inside of the door you will see the transfer belt unit. There is a Gray lever toward the front of the copier, It pulls up and to the right. The waste toner is inside that unit, it needs to be vacuumed out. Once the unit is out, there are two springs on the side of the unit remove them and there is a plastic clip that holds the belt in place. Release the clip and swing the belt up and lift it out. You will see six screws holding down a black cover, remove the screws and open, be very careful there is loose toner in the unit. Dump or vac out the waste toner and put the unit back togather and install it back into the copier and Ta Da..... Problem solved.... Good Luck.......
Feb 28, 2013 | Savin Office Equipment & Supplies
WASTE TONER BOTTLE REPLACEMENT FOR SAVIN 2400WDP
Lift the upper section and on the right side take off lower right cover. -Carl
Jun 08, 2010 | Savin Office Equipment & Supplies
Savin 9935dpe /ricoh 350 toner waste near full. Where is the
If you can locate the imaging drum unit, the ink is usually stored inside. The imaging drum has a roller with green film over it (this part may not be exposed), which is light sensitive, don't leave it in a bright area for long periods of time, or you may shorten the drum's lifetime.
You'll may have to remove the green roller (is sometimes a dark-blue or black), or some other parts, in order to find a grate. This grate is usually where the ink is dumped, though the design may differ depending on the model. Also, be careful when taking apart your drum, as it is filled with powdered ink, and if you turn it the wrong way, it will spill, and it is very very messy. If you're in an appropriate cleaning area, however, this may be a good way to locate where your ink is stored.
I'm not particularly familiar with Ricoh products, but that is how most laser-printer technology works.
Jun 22, 2009 | Ricoh Office Equipment & Supplies
1,008 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
