Toshiba Satellite A45-S250  PC Notebook
Problem for Toshiba Satellite A45-S250 (PSA40U-0C1ZRV) PC Notebook
Battery charger wires-Can they be fixed?
By bnbadspnkme on Aug 03, 2006
My laptop was plugged into the charger. Somebody got tangled up in it and the wires that go from the computer to the charger box pulled apart. I'm no electrician but am wondering if there is a simple fix for the wires or if I have to spend 90.00 for a new one. Please help!
Same Problem
Jun 18, 2008
-   my charger stop working and it has like a little beeping noise and every time that i plug it in the green light doesn't go on what is wrong with it
-   Guest
Best Solution
posted on Aug 03, 2006
Very Helpful)
zaak
Rank: Guide
Rating: 78%, 108 votes
If you can clearly identify which wire is which, simply strip off a half inch or so from each broken end, twist together, then solder or simply wrap twist with electrical tape. repeat till all wires are connected then tape into a single bundle.
Zaak
Was this helpful?
Yes
No
Solution #2
posted on Dec 20, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
YEP I HAVE THE HP DV1000 AND MY CHARGER WOULDNT WORK, I FOUND THE PROBLEM OUT AND NOTICED MY MAIN WIRE HAD FRAYED, I SIMPLY TWISTED AND TAPED MINE BACK, MAKING SURE THE WIRES WERE APART :D
Popular Solutions for Toshiba Satellite A45-S250 PC
Questions and Unsolved Problems for Toshiba Satellite A45-S250 PC
Do you recommend Toshiba Satellite A45-S250 (PSA40U-0C1ZRV) PC Notebook?
Answer
Answer
no incoming sound -- eg my Skype hearers can hear me but I cannot hear them nor any incoming audio
Answer
I have a Toshiba Satellite M45-S331 laptop. Started experiencing power issues. Whenever battery gets... (More)
Answer
when loaded and start to use every where the mouse gose across the screen it go blank or white and... (More)
Answer
Recently a friend ''cleaned up'' my computer to help speed it up. Since then no incoming sound.... (More)
Answer
my 45 just shut down power went out and no more power even when you plug it in
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A45-S250 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
