Question about Berkel 827E Gravity Feed Deli Meat Slicer
Replacement motor the motor is rotating in the wrong direction
  • liftman20 May 11, 2010
    The Capacitor is open
    Scholar:
  • 68 Answers
Did this just happen, was it running the correct direction before?
Tell me more about what you have here, and we will figure it out, sounds like a special motor that is made by the OEM and may or may not be available new,
I need more details and if it is special and has a good piece of equipment down, you can always mail it to me and I can see if I can reverse it or what the problem is
Will wbwill@sbcglobal.net
Posted on Nov 05, 2008
Is it possible fan motor in freezer wrong rotation?
Yes if you have the wires reversed..motors run in two directions polarity is what it is called....need to make sure it is spinning in the in the direction the manufacturers set...some designed to pull sir and others push...good luck..
Jun 24, 2015 | Refrigerators
? Wrong rotation ?
as far as the motor you swapped wires on motor switch two wires either two blacks or one black and white
Sep 06, 2014 | Hobart D300 Stand Mixer
Electrolux Z61a brush not rotating
There should be a rubber belt somewhere along that roller, probably in the middle, behind the bottom cover plate, Remove the plate. That belt may have just slipped off the motor shaft, but it may be broken.
The belt could possibly be installed in either of two ways. The motor shaft is not parallel to the beater bar (brushes), so the belt must twist to wrap around both the motor shaft and the beater bar. If it's twisted one direction, the beater bar will rotate the correct direction (as if drying to pull the vacuum forward). Twisted the wrong way, it'll rotate the opposite direction. Try it one way, then bump the power switch to verify that the brush is rotating the correct direction before putting the bottom cover plate back on.
Aug 10, 2014 | Electrolux Vacuums
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
I have a wall mounted accutek oval fan.been running for 5 yrs.now it wont start.i bypassed the reostat and the motor works at h speed but tuns in the wrong direction.i live in witbank in south africa and...
The motor may have a capacitor that has failed. Start Capacitors and/or motor winding "shades" are used to determine the direction of rotation, if the capacitor is checked and is defective replace it, if the capacitor is tested and is functional the fan motor may need to be replaced. it is helpful to include the model and serial number of the unit to ensure the wiring diagram is correct for your fan.
Nov 01, 2017 | Heating & Cooling
I replace a motor on my SO32 and now both rotors rotate the same way. What's up with that? I don't know what to look for.
Dear Bmjjhh,
kindly carry out the following steps.
1. Observing from top the bottom rotor should rotate in anticlockwise direction while top rotor should rotate clockwise - identify which rotor is rotating in opposite direction.
2. Another way is that the rotation of both heads top and bottom should be towards the leading edge of the rotor blades respectively.
3. Once the motor is itentified which is rotating in the wrong direction go to the electronic receiver pcb and disconnect motor coupler.
4. Using a paper pin lift the small plastic notches in the motor connector and pull out the wires gently.
5. reverse the position of the wires and insert the wires in the coupler again and plug it in the pcb.
6. Check direction of rotation it should be fine now.
Have a wonderful flying
regards
sanjay
Jan 25, 2011 | SYMA Toys industrial Syma S032 Ready to...
I need to replace my condenser fan motor. I replaced it once before but instead of blowing out the top, it was blowing on the condenser. Should it blow out of the top? If so, what direction should the...
Yes. It should blow out the top. The rotation of the fan does determine the direction of air. Either have the motor replaced and indicate the direction of rotation.
May 08, 2009 | Heating & Cooling
Which direction should the brush roller rotate?
take back to repair shop that is most likely the case thank you for useing fixya please rate me
Feb 24, 2009 | Vacuums
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Berkel 827E Gravity Feed Deli Meat Slicer Logo
178 people viewed this question
Top Berkel Kitchen Appliances - Others Experts
john raffaele
Level 1 Expert
ray gallant
Lawrence Oravetz
Are you a Berkel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
