Question about Lexmark X6170 All-In-One InkJet Printer
Paper jam X6170
Roller is not in center it is off to one side and it snatches the paper and crunches it up
    Sergeant:
  • 390 Answers
Yes, this is a paper jam. Open up your printer as if you were changing the ink. Get a torch if needed and a pair of tweezers in case it is small. Get in ther and have a good look for it. It can be so tiny and could be near the carriage that is off to the side, in the roller and its teeth or further down. he paper cruching is because of the jam and the fact the carriage cannot center itself. Good luck.
Posted on Oct 28, 2008
Crunching paper
There is most likely to be paper jammed in the side it is crunched.
Apr 17, 2014 | Lexmark X Office Equipment & Supplies
Paper crunches inside the printer
Check any paper particles jammed in side? open fuser assembly, check teflon sleeve,pressure roller & .. found any damage replace it if available or else replace the fuser assm. Note: Little bit technicality required to do the above said process..
Oct 01, 2011 | HP LaserJet 1100 Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
The printer is only pulling the paper half way, and then displays paper jam. How do I fix this problem?
Clean the paper roller and check is their any dust in it.
Chek for the virus in your system.
Dec 15, 2010 | Lexmark X6170 All-In-One InkJet Printer
How do you stop paper jamming on a belt sander
there is a knob that moves the front roller [rotates] the roller side to side to center a moving belt - the grit belt. the roller has a slight bevel from the center out to the edge. both edges. use the trigger to start the belt in short spurts and move the knob. eventually you'll get the belt to track on center.
Oct 21, 2009 | Tools & Hardware - Others
Paper Jam
Usually with lexmarks its the sensor in there, it either has something going across it
Ths other thing it can be is the pinch roller that is in there if you can clean it with a qtip and achohol
Aug 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer crunching paper
either it's a paper stuck under roller, or along that side of the raceway, or the roller on that side is dirty, and can't grab the paper well.
Feb 25, 2008 | HP LaserJet 1020 Printer
PAPER JAM
Hi, oh dear, you have a paper jam in or near the roller or very small one in carriage. Open up unit as if rplacing cartridges, get a torch if you have to and search for tiny jam. A good clue, is does the carriage return to correct positon upon opening?
Jan 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
Paper jam/lockup
Check to see if the egg-shaped rubber feed roller is cracked. (Pull out the paper tray, it's in the middle at the front on top.) That's what I'm looking for now on the ML-1740. Seems Samsung used cheap rubber for the roller. It should only be a $.50 part if you can find one.
Aug 03, 2006 | Samsung ML1740 Laser Printer
Lexmark X6170 All-In-One InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
