Question about Tascam 2488 Portastudio Multitrack Recorder System
Hard drive partitions
Partition four has disappearred 1 2 ans 3 all show up on the menu no sign of 4 any where because i have songs on file cannot tell wether 25 percent of the hard drive has dissappeared also
any help most appricated
from nz
    Brigadier General:
  • 6,966 Answers
Offhand, it would seem that the Partition Table went bad. There are specialized programs/utilities for this purpose. One is Partition Magic (see if you can get a Demo) and other freewares. To give you a detailed procedure, pls reference this, this and/or this. Often, recovery could be performed but would require some close attention and time.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 22, 2008
  • 538 Answers
Hmmm..disappeared,,,from which viewing approach..that would be highly unlikely..however, there is one possible issue. it could be in the hidden folders..what menu are you referring to? what operating system is running?
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
How Do I Correct the Error and Recover an Acer Computer hard drive?
In order to correct the hard drive partitions so the recovery program will work, you can use a variety of tools listed below.
1) Active@ KillDisk - Use their free killdisk program to wipe the hard drive clean off all partitions.
2) Ubuntu or another Linux alternative bootdisk. Create a boot disk for the Ubuntu Live CD and boot the computer from it. During the boot process it will ask to "Try Ubuntu without any change to your computer". This is the option you want. Once Ubuntu loads, find the partition editor program under the System, Administration menu..
To delete a partition, right click on the partition that you wish to delete and select "Delete" from the menu. Once you are sure that you've selected the correct partition, and are positive that you have backed up all the files or data that you wish to save from that partition, click the "Apply" button at the top of the Window, and the partition will be deleted.
3) Use the Acer Hard Drive Format Utility, on some versions of Acer computers when you have the option to create Recovery disks, the system creates a hard drive format utility CD as well. Boot from this CD and format the hard drive.
The utility will recreate 1 partition (C: drive), after the partition has been created, you'll be able to reload the HDD with the backup media. The file is an ISO image for CD media only (not compatible with floppy diskettes). Create a CD disc from the ISO image file using a CD writer program on another computer.
Once the hard drive partitions have been deleted by any of the utilities above, you can proceed with rebooting the computer using the Acer System CD and proceeding with the complete recovery of the system.
on Jun 25, 2010 | Computers & Internet
How to partition. appreciate a step by step instruction. thanks,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
i have used this and found it a very good program and is easy to install
hope this helps you
Aug 20, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
How to format a new seagate external hard drive
Hi josernld
Formatting your drive for Windows Vista
STEP 1: Open Computer Management like this:
  1. Right-click on the Computer icon.
  2. Click Manage.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
STEP 2: In the pane on the left, under Storage, click Disk Management.
STEP 3: Right-click the drive that you want to format-be sure it's the correct drive-then click Format
STEP 4: To format with the default settings, in the Format dialog box, click OK, and then click OK again.
Formatting your drive for Windows XP STEP 1: Open Disk Management like this:
  1. Right-click on the My Computer icon.
  2. Click Manage.
  3. In the pane on the left, under Storage, click Disk Management.
STEP 2: Right-click on the drive you want to format. Be sure it's the correct drive.
STEP 3: If you want, you can type a name for the drive in the Volume Label box. This is an optional step.
STEP 4: Click the file system that you want to use in the File System box. You can also change the disk allocation unit size, specify whether you want to perform a quick format, or enable file and folder compression on NTFS volumes.
Note: Before changing the default allocation unit size please refer to Microsoft Knowledge Base Article 314878.
STEP 5: Click OK. When you're prompted to format the drive, click OK again.
Formatting your drive for a Mac STEP 1: Open Disk Utility like this:
  1. Click Finder.
  2. Click Applications.
  3. Click Utilities.
  4. Click Disk Utility.
STEP 2: Select the drive you want to format. Be sure it's the correct drive.
STEP 3: Go to the Partition tab.
STEP 4: Click on the Current Volume Scheme drop-down menu and select One (1) partition.
STEP 5: Click Options. From the Partition Schemes provided:
  • Click on the GUID Partition Table radio button.
  • Click on the Apple Partition Map radio button.
STEP 6: Click OK. Select other options as desired (e.g., Volume Name, Format, etc).
STEP 7: Click Apply. The Partition Disk screen opens.
STEP 8: Click Partition. At this point, the volume dismounts from the desktop and the drive is partitioned and formatted.
Note: When Volumes are created, Time Machine may open, asking if you would like to use the volume for backups. Click Cancel to proceed.
STEP 9: When finished, select the Disk Utility from the Apple Menu and choose Quit Disk Utility.
Feb 17, 2011 | Seagate Computers & Internet
I want to format my 2 T hard drive from NTSF to fat 32 , how to do please help
Ok this fix will erase all Partitions on the drive, Make sure you have all data back'd up.
Open Command:
Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator. Or Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
You should have a black MS-DOS prompt on your screen. Type DISKPART in and press enter. Another window will open
Type: list disk It will the display list of devices with memory storage. Find your disk, It should be in a Table(kinda). You have to locate it by its size. so look for 1TB(1000GB) In this Example its Disk 2, yours may differ.
type in: Select disk 2
Wait for one command to complete before running another
You should be left with a working FAT32 Device :P
Regardz Sinn3D
Oct 27, 2010 | Western Digital My Book Essential 1TB...
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions?how?
yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start, right-click My Computer, and select Manage from the menu that appears. When you see the Computer Management window, click the Disk Management item listed underneath the Storage heading. You then see the main Disk Management pane in the right side of the Computer Management window.
2.Creating the partition: Unallocated space appears as an Unknown Partition in the Disk Management diagram, you can use it to create a new partition in some or all of the space. To create your new partition, you need to right-click on the part of the diagram that represents the unallocated space, the unallocated space has a black stripe running along the top and then choose the "New Partition" on the menu that appears. To create your new logical drive in an extended partition that has free space The free space has a light green strip along the top, right-click on the free space then choose New Logical Drive from the menu that appears. Now you will see the New Partition Wizard.
The Partition Wizard will asks you to specify the following:
1 The Type - Primary, extended, or logical partition. Your hard drive can contain up to four primary partitions, or three primary partitions and one extended partition. Choose the primary partition if you are created a partition in which you will install an operating system (this is unusual situation). Choose extended if you plan to create several logical partitions within it. The logical partition type is available only if you choose to create the new partition in an extended partition with some free space.
2 The Size - You may use the entire available space, or leave room for more partitions. The Partition Wizard will displays the minimum and maximum size for the partition, this is based on the space where it will be stored
3 The Drive letter or path - Two operating system on your computer. You may select any unused letter, but the wizard will offer the next available drive letter. To Mount in the following empty NTFS Folder, you need an NTFS partition with a drive letter on the same machine. You may select the "Do Not Assign A Drive Letter Or Drive Path" option, this will let Windows assign a letter later, usually the default drive letter.
4 The File system - The default is NTFS (recommended), but you can use FAT32 (not recommended) as well. Both NTFS and FAT32 will efficiently utilize disk space on large drives.
Note: NTFS has better security features, the better recovery capabilities after a major crash, and has file-level compression built in. NTFS will also give you the option of enable compression.
5 The Label - Type a name for the partition, name it something that will indicating what you will use it for, data files, my files, fatboy one, etc.
I hope this solution was helpful.
Aug 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I've been exporting master tracks and now I've reached a point where the tascam says, "master track too big". how do I free up space on the FAT partition?
If you NO LONGER NEED the songs/data in the FAT partition, you can delete the entire contents thereof in the manner detailed below. Note that these instructions were taken directly from the Neo manual.
1 With the transport stopped, from the DISK menu, highlight FAT REFORM, and press YES/ENTER.
2 A pop-up message appears.
3 Ask yourself once more if you want to erase all the data on the FAT partition. Press YES/ENTER to continue with the operation when a pop-up appears, or press NO/EXIT to halt the operation.
4 When you reformat the FAT partition, four directories (folders) named WAVE, SMF, BACKUP and UTILITY are automatically created. These folders are used for audio files, Standard MIDI Files (SMF) and backup data and system utilities, respectively.
...this will reformat and thereby EMPTY the contents of the FAT partition and create the 4 new, empty files as listed above.
THINK before you do this though, and I hope this helps.
Feb 07, 2010 | Tascam 2488 Portastudio Multitrack...
Tascam DP-02CF: How to transfer files to my computer?
You can't see the fat partition from within the DP-02. It's there, but only your PC will be able to read the contents of the fat partition when you have the USB 'opened' on the DP-02. The manual states that if your CF card is less than 5 Gb in size than you will only see/be able to select one partition. The default CF card that comes with the DP-02CF is only 1 Gb.
If you've created a backup or exported your wav files properly and everything is working ok with the CF, then you should be able to see backup or wav files showing up in the fat partition while connected to the PC. Even if nothing is backed up or exported you should still see the directory structure from your PC with the three folders, BACKUP, WAVE and UTILITY. As you are not even seeing these directories, what may have happened is that the fat partition had become corrupted or these folders had gotten erased.
I would have thought that reformatting the FAT partition would have fixed this problem however and that the DP02-CF would automatically recreate the required directories on the CF media after a reformat. The manual is unclear on this however.
So a couple of things you could try:
1. You describe opening the USB connection as 'push the USB button and then hit enter'. I was assuming you meant that you were selecting 'usb' from the menu and then pressing the 'enter' button to open the usb connection. You may wish to verify that the usb connection is being opened properly first.
2. If the connection is opening ok, and after a reformat you still aren't seeing any folders in the fat partition while connected to your PC with the usb open, you might wish to try to recreating those directories in the FAT partition yourself. While accessing the FAT partition (DP-02CF's removable drive) from the PC create the three directories exactly as named in the manual (WAVE, BACKUP, UTILITY). If that works, disconnect from the PC, try exporting a track or backing up a song again, and reconnect to the PC to see if you can see/access those files now.
Best of luck.
Jan 02, 2009 | Tascam 2488 Portastudio Multitrack...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
hi there,
the first partition is always the healing partition so u can use the other healing partition for your files/docs.
Apr 10, 2008 | Dell Inspiron 6400 Notebook
Tascam 2488 Portastudio Multitrack Recorder System Logo
63 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
