Question about Scunci 900 Handheld Steam Vacuum
Adding water to scunci steamer 900
How to add water.
  • patrick_vale Feb 08, 2012
    where does the water go?
SOURCE: heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Posted on Sep 09, 2008
SOURCE: no steam
my steamer heats up but no steam come out. There is also a dial on the nozzle with an arrow, that I can not move. my phone # is 239-333-9844
Thank you! Joanie
Posted on Nov 29, 2008
Richie_asg1
  • 1036 Answers
SOURCE: steam and water both comming out
Try not to overfill it, and try again. If the level is fine, there may be a break internally or problem with the valves not operating correctly. Both need dissasembly to find out.
Hope this helps.
Thank you for using Fixya.
Posted on Dec 26, 2008
  • 143 Answers
SOURCE: my scunci handheld steamer does not dispence steam
probably full of scale in the nozzle and element common from using tap water. Purchase a product called scale clean insert and flush. Scale clean is available at department stores for home coffee makers.
Posted on Sep 13, 2009
SOURCE: Need a manual for the hand held Scunci steamer
Try this:
http://www.ehow.com/how_4811845_use-scunci-steamer.html
Posted on May 15, 2010
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
I have lost the manual
Add an extra 25% on what u usually use too add
Sep 04, 2014 | Vacuums
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
Why the euro pro shark mop model S3202 Get hot but does not steam
Unplug your mop, add vinegar, plug back in, let it sit inside a sink or tub. When all vinegar has been steamed out, then unplug, Now add "DISTILLED WATER" and repeat until all brown residue left over is gone. Then, from now on, only use "DISTILLED WATER".
Jul 08, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How much water do I add to the steam buggy
I measured it for you, from my cup.
It's 18 Fl ozs or 500 ml (1/2 litre)
Anybody know where I can buy a spare nozzle.
Jul 01, 2009 | Tristar SB Steam Buggy Vacuum
Where do i put the soap?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=548073
Posted by dopaMEAN on Apr 26, 2008
I have a Bissell Dirt Lifter that has the giant clear store compartment that you supposedly put the water in?
Do i mix the soap in with the water in this compartment or is there another location where i add the soap..
We have looked the machine over and see no other place to really put the soap...
will it ruin the machine if we just add the soap with the water in the detachable compartment?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
According to your description you do mix the water with the Bissell soap in order to dispense the solution onto the spot, it will not ruin the machine if you mix the water and soap together.
You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vinegar
Do not add anything to the tank.... Vinegar is corrosive and that would potentially be very bad.
Feb 26, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scunci 900 Handheld Steam Vacuum Logo
158 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
