Question about Sharp R-1850A Convection/Microwave Oven
Intermitten power loss
No problem with power to motorhome or any other appliances, only microwave.
  • barbcamp
    barbcamp Feb 26, 2012
    Took out microwave and put in a new one that works fine.
What kind of motorhome is it if it has a inverter it may be kicking in and out due to low voltage or a bad cell in the batteries
Posted on Feb 26, 2012
My High Point microwave ( in our motorhome). When we plug into power it may or may not come on. Unplug power and reconnect, it might come on and work fine. Have to keep trying to reconnect until it does.
First thing is to check the power point for a burnt connection. If OK then open the microwave and look, check & smell for loose connections. Check the continuity of the lead. Even just lifting the fuse and reinserting can fix the problem. Failing this voltages would have to be taken to ascertain where the breakdown in voltage is occurring.
May 16, 2018 | In Microwave Ovens
Microwave oven
An internal fuse may have opened
Aug 18, 2016 | GE JVM1490 Convection/Microwave Oven
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
Main oven wont heat
Thank you for your post, Allison! I understand that you are having concerns with your microwave oven heating. This could be because of several factors, such as: loss of power to the microwave, a displayed error message or a faulty magnetron. Please ensure that your household power circuit breaker is not tripped and that your appliance is not displaying an alpha-numeric error message or code on your control panel. If you notice an error message please comment and let me know so that I can help you further. Otherwise, if you do not notice any errors and have sufficient power you are more than likely experiencing a faulty magnetron. The magnetron is the sole component that allows the microwave to heat. This is not a typical do it yourself repair so I recommend contacting a professional to confirm this and complete any necessary repairs.
Thanks,
Chris
Dec 18, 2013 | Electrolux E30MO65GSS Convection Microwave...
Mu accuwaave makes a short noise intermittenly while trying to heat
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Mar 24, 2011 | Whirlpool Accuwave Microwave Oven
Microwave only runs for about 3 seconds.After
Chances are you have a failing magnetron.
But to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
Kenmore Microwave model 721.80019 does not heat
Hi
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. As there was power loss due to storm so I believe it could either be the the high voltage circuitry, or the circuit board . To resolve this problem, you need the assistance of a qualified appliance repair technician.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jun 07, 2009 | Kenmore Microwave Ovens
Our NN-8500/NN-8501V Micro/Convection is no longer repairable
hi Peggi and john, have a look here for repairs and new in Dallas TX area:
http://www.superpages.com/bp/Dallas-TX/Affordable-Appliance-Repair-L2069127442.htm?SRC=portals&C=Range+%26+Oven+Sales+%26+Service&lbp=1
regards from the UK :)
Nov 21, 2008 | Panasonic NN-T888S Convection/Microwave...
Power cord
If you are referring to the main power cord then you should be able to purchase one at Home Depot/Lowes of most local hardware stores... make sure you get the current rating off the tag on the appliance.. 15Amp or less can use a cord size of 14 gauge.. you should use a 12 gauge for any appliance requiring up to 20Amps ( in your case ..1100 watts minus losses within the system should allow you to use 14 gauge power cord.)
Sep 17, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave oven start button not functioning
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 30, 2007 | Microwave Ovens
Sharp R-1850A Convection/Microwave Oven Logo
75 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
