Question about Makita Saws
Makita 2704 table saw press start button saw wont start
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
danny_murray
  • 55 Answers
SOURCE: preventive maintenance
Here is a link to the owners manual
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=197
Posted on Dec 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: makita table saw switch wiring
K, from what I can remember there is nothing special about the switch, however the brake works off the armature and brushes and dirty or worn brushes will affect it. I just looked at a breakdown and there is no wiring schematic on it and I did not see any electronic module for the break. You can take the brushes out (unplug tool first) and blow the area out with compressed air. Look at the brush spring for discoloration and condition and length of brush. Makita does have a good website and also a toll free number for tech support. Their site is Makitatools.com and click on the table products and then type in your saw number. Let me know if you still have a problem and I will contact a local Makita center to get more info. Good luck
Posted on Jan 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Table saw won't turn on.
that reset is breaker and I would think that it should click when reset. I looked at a breakdown and the part number for the breaker is OLSL list 2.16 and they are in stock at Searspartsdirect.com If you have a volt ohms meter I would check the electrical starting at plug end of cord thru the breaker. Make sure you unplug tool before attempting. I would also take a look at the brushes for excessive wear and sawdust buildup. Let me know if I can help more
Posted on Jan 19, 2009
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
Table saw starts for 2 second and stops
if it is electrical u might wont to check the battery if it is gas u might wont to chek the oil or the gas if it is gas
Jun 03, 2013 | Makita 2703 10" Table Saw, Electric Brake
My 2704 is blowing fuses, there is no fault on the lead
You may have a motor winding lead that has touched the case of the motor, shorting out the windings, drawing too much amperage, thus blowing fuses. You may have to disassemble your motor and check the stator windings for a short as well as the armature windings. Also the motor could be hanging up due to bearing trouble and causing the motor to draw too much amperage. Probably the cheapest thing to do would be to replace the motor.
Jun 08, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
My 2704 bench saw has packed up. thought it was the brushes, fitted new ones. it spins up but lot of blue sparks comming out of the motor. It has done a lot of work, is it best to fit a new motor or can i...
before you replace it, you can try and clean the commutator. To do this first unplug the tool and turn the saw on its backside. remove the brushes and find a emory board (cardboard) while turning the blade by hand (use a glove) lightly touch the board to the commutator to try and clean the surface, While doing this try and notice any raised sections of the comm, if there are any then you would need a new armature and possibly field. I would try cleaning first though. Let me know if you have any more questions.
Mar 10, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
My makita 2704 table saw stopped working while cutting a 4"x2" piece of timber the motor was a little hot so left it too cool an now when i try to start it up it fires up for a second or two then...
there are no capacitators that I see. What I would do is unplug the tool and remove the brushes and check there condition for burning/wear and if you can look into the brush tube and carefully turn the motor by hand and look at the commutator for discoloration. Let me know if you need more help. You can download a breakdown at "makitausa.com"
Mar 01, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
Electric brake doesnt work unless off switch hit really hard.doesnt switch on sometimes
sounds like a faulty switch. before removing write yourself or take a photo of where the wires go. Also check the condition of the brushes, if they are too short the brake won't work either.
Jan 18, 2011 | Makita 2704 Contractors 15 Amp 10 Inch...
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
Feb 13, 2009 | Makita 2704 Contractors 15 Amp 10 Inch...
Saws Logo
80 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
