Question about Health & Beauty
I dont know how to ues my phillips qc 5040 - Health & Beauty
What is the postal code of quebec canada?
Following codes apply to quebec Canada and they depend on the exact area.
Quebec, QC / G1A 1A4
Quebec, QC / G1A 1B5
Quebec, QC / G1A 1B9
Quebec, QC / G1A 1C5
Quebec, QC / G1R 0A1
Quebec, QC / G1A 1A1
Quebec, QC / G1A 1A8
Quebec, QC / G1A 1B6
Quebec, QC / G1A 1C1
Quebec, QC / G1A 1C6
Quebec, QC / G1A 1A2
Quebec, QC / G1A 1B1
Quebec, QC / G1A 1B7
Quebec, QC / G1A 1C2
Quebec, QC / G1A 1A3
Quebec, QC / G1A 1B4
Quebec, QC / G1A 1B8
Quebec, QC / G1A 1C3
-IAmAraldite
Aug 18, 2011 | Computers & Internet
Never got the manual on my gametime ledgend 23karat watch. don't know how to set
Your watch is fitted with RONDA caliber 5040.D. Follow this link and learn everything to the smallest detail: http://www.ronda.ch/en/products/datasheet/5040.D.html Rate me, plz.
Feb 17, 2010 | Gametime Boston Red Sox Legend Series...
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
Software
Drivers and owners manuals can be downloaded HERE. There was a firmware update for the DV-5040 in July of 2009. This can be downloaded HERE, but be sure to follow the directions exactly. If you are referring to the editing software by Ulead, any editing software will work.
May 30, 2009 | Optimus DV-5040 Camcorder
I have unknow web came (QC PASSED) dont have driver How will lod
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 As you run the program, write down the info about the camera so you will know what you have .
Double click on this site and download the Camera Diagnostic Tool and run it to check out your camera and/or problem.
http://www.download32.com/webcam-diagnostics-d35065.html
I ran the diagnostic on my camera to give you an idea how well it works.
Give it a try.
Hope this helps. Bud
Jan 08, 2009 | Logitech Quickcam Chat Webcam
UE what does that mean?
Your load is too small or out of balance. Rearrage your load if out of balance or add 1 or 2 similar items to balance the load.
Nov 09, 2008 | LG WM-2277HW Front Load Washer
Tallygenicom 5040 passbook printer problem
Right, the problem lies in these triangles. They're part of what's called "lower paper feed unit" and are drien by an electromagnet to start/block when needed. This magnet has a tiny problem letting go, so the triangular wheels stop in wrong positions, blocking the paper. The best solution is to change the "clutch" with the latest UCL version (3), you'll know it for having aluminium toothed wheel rather then plastic ones.
Jul 16, 2008 | TallyGenicom 2280 Matrix Printer
Samsung P1053S error code UE
The UE is an onbalanced load fault code.. Unplug the machine to clear the code.. leave it unplugged for about 10 mins and try to run it empty.  If it persists you would be advised to contact a service technician.  Bust of luck
May 26, 2008 | Samsung WF203ANW Front Load Washer
Health & Beauty Logo
32 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
