Question about Whirlpool Washing Machines
My w/p washer md wfw9400sw01 displaying f20 code, what could my problem be?
SOURCE: 2006 kenmore smartwash quietpak4 he3t F20 code washer
Turn on the water.
Posted on Nov 24, 2007
jsrock516
  • 5911 Answers
SOURCE: duet washer WFW9200SQ00 display F20
"F20" is a water inlet problem. This indicates that you have no water or insufficient water supply. What Whirlpool recommends to do is unplug the washer and check your water inlet screens to ensure they are not clogged, check the inlet hoses for kinks, and to make sure your taps are turned on (duh! I know it sounds stupid, but I've seen it before).
To check the water inlet screens you will need to turn off the water supply and disconnect the hoses where they connect to the back of the washer. The inlet screens are located inside the tap fittings and sometimes will collect with sediment and rust depending on your water source. Some hoses also have sediment screens. Check them as well if you have them. Use cotton swabs to clean the screens, thoroughly.
Checking the hoses and taps is self-explanatory. The water supply coming into the washer should be at least 10-25 psi. Insufficient water pressure can cause problems with slow fills and/or error codes due to insufficient pressure. If you haven't had any problems before, I would suspect dirty inlet screens and/or a inlet valve failure.
If you need to replace the water inlet valve, searspartsdirect.com carries the part. Just type in your model number in the Search menu and look for item #1 under the "Dispenser Parts" heading (part #8182862). The part runs about $52.00.
I hope this helps you. If you need further assistance, please post back with any questions/concerns you may have.
Posted on Apr 16, 2008
SOURCE: Fault code F20 on kenmore he2t clothes washer
I had the F-28 code error on my 1-1/2 year old Kenmore HE2t. The door wouldn't unlock and I couldn't get the clothes out of it.
The repair tech, after calling other repair techs, decided it was the central electrical unit, page #8540540 (Whirlpool) -- now Part No. W10163007. I ordered it online for about $250 cheaper than the tech was going to charge (not including the additional labor charges).
Posted on Jun 23, 2008
SOURCE: f20 error code???
Ok, I found 2 solutions for this problem, I tried the first one, and it really seemed to work, but I think I will do the second one too.  First, if you have metal flood safe hoses, you need to look for debris blocking the filter at both ends.  I kept checking the screens at the washer end and not seeing anything, but there was debris located at the water supply end, stuck in the flood safe device that is in the metal hose.  Also, Flood safe hoses say to turn the water on to full pressure, but sometimes that can activate the flood safe device, so only turn your water supply on half way.  Make sure that the hoses are on right as well, the flood safe device needs to be at the end with the water supply, not the washer end.  You will be able to see the device (it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, it is located in the front just under the front bottom removable panel.  If you have a pet in the house, definitely check this out, a lot of hair gets stuck in that.  Just unscrew the front bottom panel, and then it is right in the middle at the bottom, a cone shaped filter.  Get a towel, because there will be water in there, too. Check out this link with pictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
Posted on Aug 18, 2008
SOURCE: F20 error code no water coming into kenmore he3t washer
The following provided by fixya has the solution to error F20.
Click here for detailing on F20 Error
Good luck and please do rate my answer.
Posted on Jan 17, 2009
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Code problem on the machine is F20
"F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
also, those flood prevention hoses they sell you don't work well with front load washers
Jul 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F20 code
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I'd like to know what the F20 message means on the Duet washer. I do not have a manual. Also, how do I get rid of it. Could it be an unbalanced load? Thank you for your assistance. Marilyn...
"F20" error code is a No Water Detected error. It is an indication that you either have no water coming into the washer, or very little water at all due to low pressure. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
May 17, 2010 | Whirlpool GHW9400 Duet Washer
I'm getting a F20 code?
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Nov 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
water supply)
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
water supply) Select PAUSE/CANCEL twice to cancel the cycle
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Jan 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
114 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
