Question about Kenmore 19001
Is the kenmore 19000 model 385.19001000 an oil free machine
Do you have to oil the kenmore 19000 witch is the emboridery sewing machine
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
  • 37 Answers
SOURCE: I need a manual for Kenmore sewing machine 385 11703700
you can go to www.kenmore.com and then click customer care. There is a phone number to call for a replacement manual.
Posted on May 12, 2009
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
  • 3 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Posted on Nov 05, 2010
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
Kenmore 19000 Scan Driver
Did you install the driver for your scanner?
Jan 21, 2008 | Kenmore 19001
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Jun 23, 2016 | Kenmore Sewing Machines
385 19000 touch screen is blank
There is probably an electronic problem with the circuit behind the knob.
Do you have a manual?
Kenmore 385 19000 Owner Manual
Feb 15, 2015 | Sewing Machines
Looking for scanner and r/w for kenmore 19000
I have one I am willing to sell. You should be able to respond to my account if you are still interested. I purchased a newer machine last year and no longer use mine.
Feb 10, 2014 | Kenmore 19001
19000 software
ine@bigpond.com
Jan 14, 2014 | Kenmore 19001
I need new software for Kenmore embroidery machne reader writer
I am having the same problem however I have Vista.....help, there has to be someone who can solve this problem. Sears is useless, the 5 person I was transferred to asked about my "lawn mower" after I had explained I was calling about my Kenmore Sewing and embroidery machine!!!! I am pretty sure my next machine will NOT be a Kenmore!
May 28, 2010 | Kenmore 19001
Sewing Machines Logo
57 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
