Question about Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil MVP Swivel Glide turning off
My Dirt Devil upright swivel glide vacumm keeps turning off after about 5 minutes of being on. The clog light indicator comes on once the vacumm has turned off. I have replaced the bag and am still having the same problem. Is there something I'm missing here? What can the problem be?
Thanks,
Ben
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: problem with my dirt devil bagles upright
Sounds like you have a clog. Either in the hose, and down below where the inlet is. I assume your brush roll is working, if not you may need a new belt.
Posted on Jan 06, 2008
reddevil6
  • 1673 Answers
SOURCE: Dirt Devil vacuum
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
  • 70 Answers
SOURCE: How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Posted on Oct 24, 2009
SOURCE: My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Posted on Aug 18, 2010
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Jan 03, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Windsor SR12 Sensor Bagged Upright Vacuum Logo
132 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
