Question about Brother CE5000 Computerized Sewing Machine
CE-5000 thumping sound when I sew, messy stitching
No sure if this is normal or not but when I am sewing at a quicker speed the machine makes a thumping sound. Its not necessarily loud but I am worried about breaking the needle or something else, Also another issue I was having last night, when I was sewing with stitch # 05 and 06 (using the correct foot) the thread pattern was really messy looking on the top of the material and very neat on the underside. I would flip the material over but than I cannot see what I am sewing. Any suggestions to fix these issues would be greatly appreciated
  • Brother Master
  • 7,365 Answers
Any sound out of the ordinary could mean that a part is worn or fixing to break or something is loose
it's very possible that the machine needs to be serviced
Posted on Feb 09, 2012
  • 749 Answers
SOURCE: upside down stitching
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
Posted on Nov 02, 2007
  • 69 Answers
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
SOURCE: looping stitches on underside of fabric
Check the bobbin to ensure it is installed correctly. Your bobbin is probably in incorrectly. You shouldn't have to change your tention yet but it is possible. this may sound stupid but the other culprit may be that your forgot to put the foot down. Hope this helps. Let us know. If you found that the tension adjustment did help call your local service center and ask for the in-house tech, ask them where the original # position is when it came from the manufacturer and re-adjust the top tention to that.
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: My ls2125i won't stitch
Start slowly, make sure your thread trails are long enough, I had this problem a LOT when I first started using this machine. (mainly because it was my first machine!)
Fabric bulge- Don't try to push the fabric through the machine, let the feed dogs do it. Your job is to guide the fabric.
Thread jumps- Also, like Outdoorsman said, the tension is probably off. On this machine, the tension knob is easy to find. It's the small one with the numbers on it. "0 1 2 3 4-5-6 7 8 9" 4-5-6 are your optimal sewing tensions. I usually sew on 4 or 5, depending on my fabric and type of stitch.
No stitches- Your lower thread may not be being grabbed properly/bobbin case may be jumping out of position. Open the lower case and make sure your bobbin case is secure, and the thread is grabbed properly.
Hope this helps!
~iamtyping
Posted on Jul 31, 2009
  • 55 Answers
SOURCE: On my Brother sewing machine The tension is all
check lower tension, make sure upper tension is correctly aligned
Posted on Nov 23, 2009
Makes a thumping noise
Most likely your needle needs replaced. As they get older, or hit a pin, they will dull. You can usually tell by your stitch quality, or the thumping sound you are hearing.
Sep 14, 2014 | Euro-Pro Sewing Machines
Not stitching correctly after using pattern selectors - zigzag very messy stitch
Describe in more detail a messy stitch. It may be the cam follower that creates the patterns is not aligned and is contacting two different cams at the same time. The machine then sews both patterns at the same time. The solution may require an expert.
Apr 03, 2014 | New Home Sewing Machines
Does not stitch, just beeps
try changing the needle
try rethreading the machine top -make sure to use every thread
guide & bobbin--make sure the bobbin is turned the right way in the
bobbin case
clean under the needle plate & in the bobbin area for lint
also try turning the machine off & then back on & see if that will
help
Oct 07, 2012 | Singer CE-200 Quantum Futura Computerized...
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
Aug 19, 2012 | Husqvarna Freesia 415
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
The sewing machine model is CE 5000PRW. The uppe...
It sounds as though the problem is with the tension in the bobbin. Check to make sure the thread is pulled through the tensioner on the bobbin case, if it is check and adjust the tension on the case.
May 21, 2010 | Sewing Machines
Can a twin needle be used with the Futura ce-200?
If the needle plate and presser foot are wide enough to accommodate the double needle, then you can use it.
Make sure the needle position is center and the stitch type is straight stitch.
Hand walk the needle at couple of stitches to be absolutely sure all is clear.
Mar 13, 2010 | Singer CE-200 Quantum Futura Computerized...
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
Brother CE5000 Computerized Sewing Machine Logo
165 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
