I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
that looks like a knoica minolta code not a kyocera.
Worn "Y" developer- is the developer at or near end of life?
Worn "Y" developer unit- is the developing unit over life?
Dirty Gamma sensor- take out Colour registration unit and thoroughly clean the gamma sensor.
Hello there again here is some more info for you Whirlpool Washer Troubleshooting: Error/Fault Codes
Whirlpool Washer Troubleshooting has been made easier since newer
Whirlpool washers generally display a consistent range of error codes
(or fault codes) when problems develop so that owners and service
personnel can quickly troubleshoot the problem and fix it easily. The
Fault codes address a wide range errors that occur with Whirlpool
washers, everything from water and power problems to basic maintenance
routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
E021 = DEVELOPING ROTARY MOTOR FAULT
Please check the connector of the developing rotary motor.
Maybe you will need to replace the DEVELOPING ROTARY MOTOR or DC CONTROLLER PCB ASSY.
Hi
Sorry cant send manual U have to buy like every one else.But here are the codes you require
It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer.
Hope this helps
