Question about Samsung CLP 300 Laser Printer
Black and Grey Printing looks watered down even with New Black Cartridge
My black ran dry and upon replacement now I get horrible black quality. It looks as if it is watered down.
Separately, what adjustment can I make so if a $50 color cartridge runs dry I can still print in black without the software deleting the print job?
  • nh42 Oct 28, 2008
    Printer software does not say the black ink has run out but quality was getting poor so I added a new cartridge. Did not improve black printing although colour is still fine.
    Any ideas?
    Rafity
The Imaging Unit needs to be replaced. If you have not printed more than 20K of pages, then you can call Samsung for a replacement of the IU for free. It is a defect I think in the product. I have 7 of these and have replaced the Imaging Unit at least 5 times to date.
Posted on Nov 11, 2008
Poor quality black in printing
If you touched the electrical contacts on the cartridge the high voltage used could be taking a shorter path to ground. Try cleaning the contacts on the cartridge and inside the printer with a lint free cloth and some 99% isopropyl alcohol then wipe dry.
Nov 05, 2013 | Epson Office Equipment & Supplies
Black in coming out grey
Ensure that cartridge are not refilled, then only you do the following process:>Got to printer properties>printing preferences>color>select print in grey scale>apply>OK.. Then check..Reason why its act like this: In printer properties if its selected as print in color, printer mixes colors to create black(which is visible look like dark grey).Select in properties as above said before clicking OK for the print command, then only printer uses mono cartridge..
Dec 18, 2011 | HP Deskjet F4210 All-In-One InkJet Printer
I have a HL4040CN copier. When the message comes up that ink is low, how can I tell what color ink cartridge needs replacing
You're just going to have to keep printing until you see which cartridge is getting dry. It'll be either the black one or the colour one. This way you won't buy the wrong cartridge. If you print black text and it starts to come out grey then it's the black cartridge that needs to be replaced. The same with colour, if the picture looks faded then you'll need a new colour cartridge.
May 11, 2011 | Brother Office Equipment & Supplies
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Samsung CLP 300 Laser Printer Logo
118 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
